Latest post 08-17-2010 1:19 PM by JC. 5 replies.
Page 1 of 1 (6 items)
  • 08-09-2010 8:17 AM
    • Topsy
    • Not Ranked
    • Joined on 05-15-2010
    • Posts 7
    BEOCOM 2
    hi have recently purchase a second hand Beocom 2 phone nad have concerns it is not fully operational. The reason for my concern is that when the phone is in the idele or charge status the display lashes. is this something to be concerned about. i have not yet set it with a PSTN.
    Filed under:
  • 08-09-2010 2:21 PM In reply to
    Re: BEOCOM 2
    The flashing means the battery is chargin...
  • 08-10-2010 7:54 AM In reply to
    • Topsy
    • Not Ranked
    • Posts 7
    Re: BEOCOM 2
    Thanks,
    How long do i have to leave it in the charger before it stops orwill it flash as soon as its placed in the charger
  • 08-10-2010 11:56 AM In reply to
    Re: BEOCOM 2
    It will flash until it is registered to the base station as well. It will also flash slowly if you have missed a call (obvioulsy once it's registered!)
  • 08-17-2010 10:48 AM In reply to
    • Topsy
    • Not Ranked
    • Posts 7
    Re: BEOCOM 2
    hi have manged to overcome the flashing and the phone is now fully charged. Have manged to locate a base station but the number on the phone display is not the same as the one on the base station and is now requesting a PIN is this normal and where would i find that?  I am trying to use it on a works socket with a number of other extensions on the same line. Thanks
  • 08-17-2010 1:19 PM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Re: BEOCOM 2
    The base you are trying to register it to is probably full. How many phones are linked to the base?
       Jonnie
