Latest post 08-06-2010 9:39 AM by Vienna. 12 replies.
Page 1 of 1 (13 items)
  • 08-05-2010 8:27 AM
    • fraberg
    • Not Ranked
    • Joined on 10-26-2007
    • Norway
    • Posts 40
    • Gold Member
    New specifications BV 10-46
    3 HDMI (also 10-40)
    No white cabinet
    Contrast ratio 5000:1
    http://www.bang-olufsen.com/specifications?productid=733
    New screen ? MK ?
    Frank
  • 08-05-2010 3:37 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: New specifications BV 10-46
    New specs??? It's only just been released? Are you sure it's an update?
    Good lord, I'd be fuming if I'd bought the BV10-46 and there was a major update, so soon.
  • 08-05-2010 3:48 PM In reply to
    • fraberg
    • Not Ranked
    • Norway
    • Posts 40
    • Gold Member
    Last time i checked the specs. and i printed it out it says 2 HDMI ,contrast ratio 4000:1 cabinet in black and white so i assume it is an update of screen ?
  • 08-05-2010 5:46 PM In reply to
    This is my first post. I have lurked a while but now its time to start contributiong to the forums
    I have just taken delivery of my 10-40 yesterday. I was told that it has 2 hdmi's by the installer so I am not a happy boy if the TV has had an update. If it does, would I have any comeback as I was under the impression that it was the latest available.
    How do I check the type etc.. I'm still trying to figure it all out
    K
  • 08-05-2010 6:18 PM In reply to
    beoladk:
    welcome
    beoladk:
    I hope you get a quick resolution
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 08-05-2010 7:07 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    fraberg:
    3 HDMI (also 10-40)
    No white cabinet
    New screen ? MK ?
    Frank
    US (component) and EU (SCART) versions (may) have different specs !
    As far as I know BV10-40 EU and 10-46 EU have not been updated yet!
    ... "it's planned - but not for the next ?months/?weeks/?days" ...
    See my posts regarding a similar issue on 8-40 EU spec-sheet
    and the immediate reaction of B&O to this "misleading specs" issue ...
    http://forum.beoworld.org/forums/t/34326.aspx
  • 08-05-2010 10:43 PM In reply to
    Yes, for example the US BV10-40 has three HDMI's, not two. I seem to recall someone mentioning it's because one of the inputs is taken over my some kind of module in the EU?
    Leo
    BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
  • 08-06-2010 2:43 AM In reply to
    Total guess but differences between the US and EU versions might be due to the population of an HDMI 'socket' on the EU board by the DVB-HD tuner?
  • 08-06-2010 3:18 AM In reply to
    My guess, the 3rd hdmi is reserved for an hdmi-expander. (Gefen)
  • 08-06-2010 4:38 AM In reply to
    also the specifications of BV10-40 and BV10-46 on the german B&O-Homepage have been changed:
    http://www.bang-olufsen.de/specifications?productid=733
    Regards
    Räuber
  • 08-06-2010 7:31 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    KingOfSnake:
    Yeah, but that doesn't account for the change in contrast ratio etc. BV10-46 has only been released!
  • 08-06-2010 7:46 AM In reply to
    To my knowledge the DVB-HD use the "third HDMI". Unfortunately you will not have access to the third HDMI if you choose a BV-40 without the DVB-HD.
    In the BV-40 US version there is no DVB-HD option, hence the third HDMI.
    Regading Gefen expander it occupy one HDMI but give 4 inputs. So, you win three more HDMI:s, i.e you will have 5 in total.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 08-06-2010 9:39 AM In reply to
    • Vienna
    • Posts 712
    Raeuber:
    Regards
    Räuber
    ... and have been changed again Smile
    *g* As before on the BV8-40 page, also this "misleading spec issue" has been straightened
           out immediately
    - the line "DIGITAL VIDEO CONNECTIONS" "3 HDMI" simply does not
           exist anymore ... Whistle
