Thanks for the warning JC, I may as well try again with the new version - it
won't make much difference, I still use my 6000 with the earset for work - the
5 is mainly used if the phone rings and I happen to be near it or to change the volume on the TV.
It makes a very pretty paper weight!!
G - a few genuine questions: when did you buy your phone - do you have the speaker base - does it all work fine for you?
