Latest post 12-25-2011 9:56 AM by Aad Jansse. 13 replies.
Page 1 of 1 (14 items)
  • 08-04-2010 7:18 PM
    Party!!! [<:o)] Beomaster 1700 or 2000
    Hi all from Australia,
    I looking at buying either a Beomaster 1700 or Beomaster 2000. Any advise on which is the "better" unit is most appreciated. They both are from an collector that looks after his B&O collection.
    Firstly what should I pay for these and in terms of their quality build , which is better.
    Im also going to attach some good speakers to them, so all the advice I can get is appreciated.
    I think Im now becoming a bit obsessive with these products ...LOL
    Thanks and have a nice day.
    Michael
  • 08-04-2010 10:11 PM In reply to
    Re: Beomaster 1700 or 2000
    Greetings to you "downunder", from "up north".
    Well -it depends on which BM 2000 you're talking about. There are 2 different receivers called 2000 -one from the early 70's and one from the mid 80's. In any case -I would go for the 2000. But that's just me Smile
    I don't know the pricelevel where you live, but in Denmark they are quite cheap: 50-100$ (US). The 2000's are quite common here -the 1700 is a bit rare -but, then again -not the most sought after.
    Steffen
  • 08-05-2010 2:01 AM In reply to
    The 70s 2000 is a very good one - excellent amplifier and worthy of good speakers - the inevitable S45-2 comes to mind. The 1700 ( I take it you mean the 80s receiver) is very pretty but the tractor controls break, the clutches slip and the amplifier is indirectly coupled and nothing like as good as the 1500 it replaced.
  • 08-05-2010 3:10 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Get both !
    The Beomaster 2000 (if the 1970's version) is a beautiful receiver with a superb sound.
    There are a few common faults but not many and all are fixable.
    The Beomaster 1700 may not be a technical wonder but it is a unique design and most tractor belt
    problems can be solved.
    Reproduction rubber clutch "washers" are available.
  • 08-05-2010 4:34 AM In reply to
    I have a 2000 in white and it is a great sounding amp. It also looks fantastic, but they do tend to blow the dial lamps as far as I know and replacement can be a bit of a problem if you're not electronically minded.
  • 08-05-2010 5:16 AM In reply to
    j0hnbarker:
    Same here! (Martin's lamps (inc dial lamp) still working!)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 08-05-2010 7:33 AM In reply to
    Thanks to all of you and your great inputs. Looks like I will have to buy both. I love the look of the 1700, while it sounds like the 2000 has the edge on the sound quality. Ill have to find some S45's as well......So I guess i will play the 2000 and admire the 1700.
    Thanks, once again...
    Michael
  • 08-05-2010 11:37 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I have a Beomaster 1700 which I bought purely for its quikiness. I didn't want it to be relegated to being simply something to be admired on looks alone so I have it connected to my PC with some CX50's.
    Works great in this application & always gets admirred.
    Chris.
  • 08-05-2010 2:38 PM In reply to
    One superb thing about the 1700 is that unlike the 6000 quad, the display panel is glass so is usually unmarked. I also love the 'bonnet stay' which makes it easy to service. Amazing how little is inside it mind you!
  • 08-05-2010 4:43 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Peter :
    You can't really compare the 6000 Quad and 1700 Surprise I have both and the 6000 is a masterpiece. Strange how you aren't very fond of the 6000 Quad?
    Durban South Africa
  • 08-05-2010 4:49 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Dillen:
    Martin, have the washers got to do with selection buttons not working. Mine don't click into place! Just pop back up as soon as I let go!
    Durban South Africa
  • 08-05-2010 4:53 PM In reply to
    • Dillen
    • Posts 5,008
    No, that's usually the power switch not releasing completely, thereby not allowing other switches to latch in.
    It will need a good internal cleaning of dust and oxidation to move freely again. Fiddly job but possible.
    Worn rubber washers will cause slippage within the clutch mechanism.
  • 08-05-2010 5:01 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Dillen:
    Thanks for the tip Martin!
    Durban South Africa
  • 12-25-2011 9:56 AM In reply to
    • Aad Jansse
    • Not Ranked
    • Joined on 10-12-2009
    • Rotterdam (Neth)
    • Posts 6
    • Silver Member
    Hi Martin,
    I can lay my hands on a BM 2000-2801, seems to be a kind if "luxury teak finish", 100% working condition; they ask
    50 Euro's. Is this real value for this type of machine?
    regards,
    Aad
    Bm1200
