Hi, sometimes the contactors at the bottom of the 2 units become loose and you get this message, it happened to me some time ago, I just had to use a tweezer to make the 2 contactors from the handset closer & in better contact with the base, and it worked again.
Maybe it's another issue, but on mine the contactors were the only problem..
Reunion Island is greeting you!
