Latest post 08-27-2010 6:52 PM by cozza. 2 replies.
Page 1 of 1 (3 items)
  • 07-29-2010 6:22 AM
    Avant DVD fault
    I have an Avant 8453 with a DVD fault. The drive plays normally for approx 1 minute then cuts out. Needs to be reset (TV to standby) to play again or eject. Engineer tried another salvage drive module and it did the same. A new chassis is required so uneconomic. Does anyone have experience of this fault? I recognise the policy is to swap modules but perhaps someone has experience of individual component failure leading to this "timing out" of the drive.
    Thanks for any advice
    David
  • 08-02-2010 7:22 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    Travel [ap] Re: Avant DVD fault
    Check the DVD power supply module - small switch mode supply in the bottom of the avant under the main chassis. It's a seperate part to the main chassis and a likely suspect.
  • 08-27-2010 6:52 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Re: Avant DVD fault
    As a follow up for any AVANT DVD owners experiencing the same fault symptoms, this problem has been resolved.
    It was caused by a faulty DVD power supply module (PCB 75).
