dsc8w:
Nick.
No just the basic SKY with all channels, incl Sky sports, but the subscription is going up to £51.00 per month, which is a bit much just to get Sky sports.
I'm more concerned about this so called new chip to be put into my Beovision 3, and WHY
David
David,
Sky is just about the only STB that appears on all the chips (because they keep the same coding even with later updates.) So, as Nick suggests, your best option is to just stop subscribing to Sky. You will still get all the free to air broadcasts and can rearrange them on the Sky EPG as favourites to avoid having to trawl through all the encrypted programmes. The only draw back to this approach is that Sky will not let you have channel 5 and will give you ITV Midlands unless you pay them £20 for their 'Freesat' card.
If you wanted to change your receiver for the Freesat broadcasts, you are best to take a look at the STB list on your current TV. (Double click menu etc.) You will probably find no current freeview boxes, but one or two satellite boxes like the Topfield 4000 that you can still get and use for Freesat. (Remember that there will only be a handful of the 60+ STBs that were intended for the UK.)
If you want to update the chip the major part of the cost will probably be the call-out for a dealer visit. I got around that by buying a used HDR1 which had the later chip/PUC already in it, giving me additional STB control and recording for the same price as a call-out.
If you search Beoworld you will find more advice on this topic.... like using the Lintronic website to compare codes between STBs if you wanted to take a chance on an old Humax listed on your current chip giving you control of a later Humax model.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
