1st March February 2012
Latest post 08-03-2010 7:38 AM by Vienna. 10 replies.
07-28-2010 1:51 PM
BeoGreg
- Joined on 07-24-2008
- South of France
- Posts 139
Select Beo4 navigation wheel ?!
Hello Peter and Svend fans,
I just received a Beo4 with navigation wheel (to test what's wrong with the IR receiver of my BV10-40) and I'm unable to select the right remote in the menu.
Each time I select "Beo4 with navigation wheel" in the "choice of Beo4" menu it goes automatically on "Beo4 without navigation wheel" and stays like that.
I can't select it and it's frustrating.
Any clue here please ?
Cheers,
Gregory
Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Re: Select Beo4 navigation wheel ?!
Your remote is set to work as a normal beo 4 out of the box (mode 2). you have to set it to mode 3 then you can select with navi. press list and st.by at the same time to enter the setup on beo 4.
BeoGreg
- South of France
- Posts 139
Thank's a lot, can't wait to try it tonight at home !
I will let you know then.
Cheers,
Gregory
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
The Stig - ver. 1.7:
I know mode 2 is for "old" Beo4 use with navigation button just for pressing GO and BACK is EXIT...
Mode 1 and mode 3 are for the new navigation function - with some nice new features btw - But what is the difference between mode 1 and 3?
It´s not mentioned in the manual....
Stefan
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
stefan:
... But what is the difference between mode 1 and 3? It´s not mentioned in the manual....
Depending on the TVs of your link system you should select
either Mode 1:
- When all televisions have the Beo4 setting menu and - When no television in the link system is operated with an older Beo4
For instance: Main room : A1 chassis e.g. BV 7-40 Mk3/4/5 Link room 1: B6 chassis e.g. BV/BC 6-26 Link room 2: C2.x chassis e.g. BV 10-40/46
or Mode 2: (default setting ex factory)
- Works like Beo4 (162x) - When at least one television in the link system does not have the Beo4 setting menu … - … or is operated with old Beo4
For instance: Main room : A1 chassis e.g. BV 7-40 Mk3/4/5 Link room 1: B6 chassis e.g. BV/BC 6-26 Link room 2: S2 chassis e.g. Avant/Beosystem 1/2
or Mode 3:
- When a television with C2.x chassis is placed in the main room (with navigation button´selected) - When there is no television with A1 chassis in the link system - When at least one link room television in the link system does not have the Beo4 setting menu - When no television in the link system is operated with an older Beo4
For instance: Main room : C2.xx chassis e.g. BV 10-40/46 Link room 1: B6 chassis e.g. BV/BC 6-26 Link room 2: S2 chassis e.g. Avant/Beosystem 1/2
stefan
- Posts 1,733
Thanks for your reply. Can all LCD Beovisions be upgraded to "Beo4 setting menu" ?
There is a BV7-40 MKIII, a BC6-26 and a BV6-22 in my setup.
Stefan
Vienna
- Posts 712
stefan:
As far as I know - not being 100% sure about it
!Yes! - for BV 7-40Mk3 - SW update needed ?Yes? - for BC6-26 - SW update needed ! No ! - for BV6-22
stefan
- Posts 1,733
Yes, thanks, just what I expected...
My BV7-40 will be updated next week. I just got my (first) Beo4 navi
Stefan
Vienna
- Posts 712
When the labtop is coming to your house, try to update the BC6-26 too.
As I understand the issue, due to different hardware, some can be
updated to be Beo4 1710 compatible - others not.
BeoGreg
- South of France
- Posts 139
So, in mode 3 it worked with BV10-40.
Thanks a lot again !
BTW, the new setup "beo4 with navigation wheel and selected in the menu" didn't change my IR receiver problem.
New beo4 is going back to the shop.
Cheers,
Gregory
Vienna
- Posts 712
Vienna: ... some can be updated to be Beo4 1710 compatible - others not.
BV 9 / BSys3 / BC 6-23 /BC 6-26:
If IOP version is 23.00 or higher the TV can be updated, if version lower than 23.00 it can not
Page 1 of 1 (11 items)
