Latest post 07-30-2010 11:07 AM by Alain-Olivier. 4 replies.
Page 1 of 1 (5 items)
  • 07-27-2010 7:12 PM
    Beo4 on a Beomaster 5500
    Bonjour,
    Anyone would know if and how I can adjust loudness, treble and bass on a Beomaster 5500 from a Beo4?
    Regards,
    Alain-Olivier
    Montréal
    Filed under: ,
  • 07-28-2010 2:28 AM In reply to
    • djram
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 78
    • Gold Member
    Re: Beo4 on a Beomaster 5500
    Bonjour!
    Add 'A.SETUP' to the list on the Beo4. After you have added it to the Beo4 list, press list until 'A.SETUP' appears, press 'GO' and then press list agin and 'BASS', 'Trebble' and 'Loudnss' can be accessed. Once the desired parameter is shown on the Beo4 display, press 'GO' and then use volume up and down button to adjust the parameter. However, the settings made this way will not be stored after the beomaster is put to standby. I do not know how to store since there seems to be no 'STORE' command on the Beo4 like there is on the Beolink 1000.
  • 07-28-2010 2:46 AM In reply to
    Not with mine at present, but pressing GO twice might store it.
  • 07-29-2010 2:33 PM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    Found it! 'S.STORE' is in the 'A.SETUP' sub menue along with bass, trebble and loudnss, simply press list until A.STORE appears an then press GO and whatever changes made to the sound will be stored. Strange that i did not see that before, probably stopped pressing list after i found bass trebble and loudnss. Happy soundtweaking!
  • 07-30-2010 11:07 AM In reply to
    Worked as a charm, you are the best. Thanks
    Alain-Olivier
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
