Latest post 08-13-2010 10:14 PM by expoman. 1 replies.
Page 1 of 1 (2 items)
  • 07-27-2010 3:32 PM
    Using a UK Beocom 2 in the USA
    Hi, I hope you can help.
    I have a 2003 manufactured blue Beocom 2 which I purchased in the UK a few years back. I was using it in my home in FL for a while with the UK base station, just running through an adaptor. However, my cat chewed through the cable and killed the base, thus leaving me with a dead phone. If I can avoid replacing the UK base with another UK one then that would be ideal, so I purchased a new US Beoline base in the hopes that it may communicate with the phone, minus the caller ID.
    Unfortunately, I cannot get the phone to register with the base at all, so do any of you know if this is even possible or if I need to bite the bullet and just buy a US handset?
    Thanks in advance,
    Dave.
  • 08-13-2010 10:14 PM In reply to
    • expoman
    • Top 500 Contributor
    • Joined on 04-17-2007
    • United States
    • Posts 222
    Re: Using a UK Beocom 2 in the USA
    Sorry. Not going to work. Bases use two different frequencies. 1.9 ghz in Europe and 2.4 ghz in the US. I would look for another UK base on eBay or buy a used US handset on ebay and sell your European handset.
