Latest post 07-29-2010 2:25 AM by yachadm. 1 replies.
Page 1 of 1 (2 items)
  • 07-26-2010 9:39 AM
    beogram 1202 Din connection
    Just got a beogram 1202 record player off ebay. It didnt mention it in the description but the Din connection is broken and is basically just an open wire. It's connected into the beogram put the din connector is missing. I know it needs to have a 5 pin male connection on the end. I'm planning on connecting it to a beocenter 1400. I don't know anything about wiring but i do have a spare Din lead lying around, I dont know if i can rewire it into this, looks a bit old and confusing. Does anyone have any advice in how to get this beogram connected to my beocenter? not sure if repair stores would be able to wire it as its so old. Any help would be much appreciated.
  • 07-29-2010 2:25 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: beogram 1202 Din connection
    Hi Danny
    Check this page
    http://www.electronics2000.co.uk/pin-out/dincon.php
    Scroll down to the Phono/Aux diagram
    You can see that 3 pins are connected:
    Pin 2 - Earth, Pin 3 - Left channel, Pin 5 - Right Channel
    If you know how to solder, great, otherwise take this diagram to your local service center, and have them solder it for you.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
