Latest post 07-24-2010 12:15 PM by BeoGreg. 8 replies.
Page 1 of 1 (9 items)
  • 07-22-2010 1:25 PM
    • tkl95
    • Not Ranked
    • Joined on 08-10-2007
    • Posts 13
    BV 4-65 IR issue
    Having brand new BV 4-65 D12 panel and new BS3, software 9.01 and the internal IR as well as test with external IR both Beo4 & Beo5 are very slow and/or do not react at all.
    Also tested with MKII BS3, same issue.
    Anyone ever had this problem and/or knows what would create this issue and how to fix?
    tk
  • 07-22-2010 4:26 PM In reply to
    Re: BV 4-65 IR issue
    I don't have this issue with my BV4-65. Didn't know that B&O updated the panel to D12... since when? How does is compare to D10?
  • 07-23-2010 5:23 AM In reply to
    • tkl95
    • Not Ranked
    • Posts 13
    hi raveny,
    I wanted to change my BV4-50 to a BV4-65 but did not want to have an "old" panel.
    I did myself some investigation on the Panasonic site, here is the link to the D12 specs: http://panasonic.net/proplasma/products/65pf12/index.html
    I asked my dealer to let me know when B&O would deliver the D12, and it was announced as supported June 2010.
    Don't know the specs on the D10 as I only compaired the D11 against the D12, but I'm certain the Panasonic site has the info.
    tk
  • 07-23-2010 9:42 AM In reply to
    • BeoGreg
    • Top 500 Contributor
    • Joined on 07-24-2008
    • South of France
    • Posts 139
    • Gold Member
    I have the same issue on my BV10-40.
    I must be at two meters of the Tv in front of it (without my two years old daughter in front of me !) to have a good working remote.
    Never experienced that with my MX or Avant before !
    We changed the IR receiver but it's still the same.
    So next step is to try the new Beo4 "navigation wheel" and select it in the Beo4 menu.
    Still waiting for that new remote...
    Gregory
    Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...
  • 07-23-2010 2:11 PM In reply to
    • tkl95
    • Not Ranked
    • Posts 13
    hi Beogreg,
    Why do you think the new Beo4 will solve the issue?
    I have this problem with both, the Beo4 AND brand new Beo5.
    tk
  • 07-23-2010 3:10 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Might be plasma "waves" disturbing the signal.
    Try repositioning the ir-eye or maybe get an updated version - if this exists.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-23-2010 3:52 PM In reply to
    kallasr:
    Most likely, but
    kallasr:
    For at least the past 2 years, improved ir-eyes has been sold with the new systems
    so
    kallasr:
    might be the solution
    I would fit the ir-eye directly beneath the panel without getting the plasma "waves" directly on the ir-eye.
  • 07-24-2010 6:27 AM In reply to
    • tkl95
    • Not Ranked
    • Posts 13
    hi Beobuddy,
    the BV4-65 has the IR Eye fixed on the right top corner of the screen so it cannot be repositioned.
    dealer also tested with external IR Eye and it has the same issue.
    I was more thinking of BS3 software issues.
    tk
  • 07-24-2010 12:15 PM In reply to
    • BeoGreg
    • South of France
    • Posts 139
    • Gold Member
    On a software update (126) my RE-BL receiver for PS3 (via PUC) stopped working properly.
    The only buttons of the Beo4 working where the ones of the new Beo4 navigation wheel.
    It works fine with update 127 (RE-BL).
    So it seems that the Tv "whants" beo4 with navigation wheel (can't explain more in english sorry).
    My tech thinks that also.
    Whait and see...
    Gregory
