As a newbie on here, firstly let me thank you for taking the time to read and advise.
I am now on my second Beovision Avant 28" and am delighted that I managed to hunt down a low hour example. I am extremely pleased with the picture and sound that the tv gives and was having thoughts about trying to harness these qualities.
I had read somewehre that the Avant would accept the early models of the Thomson Sky HD box , is this true ? and if so will it enhnce the already stunning picture or is the imporvement negligable?
On a second note. I was looking at the purchase of a 5.1 system to compliment the great sound I get from the Avants active system.
Am I right in assuming that I would not require the "sub woofer" part of the 5.1 system and would only require the smaller speakers ? If this is the case can anyone suggest a manufacturer or indeed a system that would suit the sound of the avant.
I have purchased the 5.1 Dolby card for my avant and am aware that I dont want to cheapen the sound with a lower grade speaker system.
If the above is not possible, is it possible to purchase a B&O speaker that can be teamed with the Avant to keep the great sound going.
Thank you in advance
