Latest post 07-24-2010 12:04 PM by Die_Bogener. 3 replies.
Page 1 of 1 (4 items)
  • 07-21-2010 4:44 PM
    • nitro2
    • Top 500 Contributor
    • Joined on 10-08-2008
    • belgium
    • Posts 84
    beolink 5000 communication problems
    Hi forum ,
    I have a bl5000 which has a irregular communication problem .
    Sometimes it is not possible to switch my bm7000 on , the only way to get the bl5000 to communicate again ,  is the use of another remote and then watch the bl5000 display to see if it cicks in.........
    Is this problem also caused by a capacitor issue like in the bl7000 ???
    If it is , who can give me info on this ????
    i have noticed there is not much documented about the bl5000
    any help is highly appreciated
    nitro2
  • 07-22-2010 10:27 AM In reply to
    Re: beolink 5000 communication problems
    Is it possible that the BL7000 interferes with the BL5000? Does it make any difference if you cover the BL7000?
  • 07-24-2010 8:10 AM In reply to
    • nitro2
    • belgium
    • Posts 84
    i have tried removing the bl7000 from the room , but the problem with the bl5000 remains.
    so i assume it would be a bl5000 problem .
    it looks like it needs to be woken-up ......................
    nitro2
  • 07-24-2010 12:04 PM In reply to
    It's quite the same problem like the BL7000. Caps on the lower board... caps with dirty black feet. Whistle
