1st March February 2012
Latest post 07-22-2010 7:22 AM by Dmitry. 5 replies.
07-20-2010 5:50 AM
Dmitry
- Joined on 05-17-2010
- Rostov-on-Don, Russia
- Posts 36
Is it possible to switch on PHONO with Beo4 on BM5500?
Hello, everyone!
I've bought the nice Beogram 5005 LP from Spiros (specal thanks for the good packaging!)
Is it possible to use Beo4 remote to switch the BM5500 to PHONO?
Now I have to use the old Beolink 1000 for it, while Beo4 can control every other function, when the LP is playing.
Thanks!
Dmitry
Beomaster 5500, Beogram CD50, Beogram CD5500, Beogram 5005, Beogram 5500, Beolink 1000, Beo4, Beovox 3702
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
Re: Is it possible to switch on PHONO with Beo4 on BM5500?
Yes it`s possible. You will find a PHONO button in the list, if your Beo4 is one of the very early ones. If it`s a newer one you can use the N.RADIO button, it`s the same IR command.
Stefan
Dmitry
- Posts 36
Thanks, Stefan!
There is no separate PHONO button- should I program the N.RADIO for it somehow?
Thanks!
stefan
- Posts 1,733
The PHONO- ( or N.RADIO) button is in the LIST function. If you press LIST several times you will find additional functions.
If you press LIST several times and PHONO - or N.RADIO is displayed just press GO and your BM should power up in PHONO mode.
If you don`t find these buttons in the list you must add it. Pres and hold STANDBY - press LIST - now ADD? should be displayed - press GO - press LIST until you find PHONO or N.RADIO - press GO - now the button is added to your list. You can now activate your BG by pressing LIST (until PHONO (N.RADIO is displayed) and then GO. Hope this helps.
Stefan
Dmitry
- Posts 36
Stefan,
Thank you very much for your great help!
Will try to do that tonight, and will report.
BR
Dmitry
Dmitry
- Posts 36
Thanks a lot for a detailed advise- I've added the N.RADIO button, and now works perfectly!
Page 1 of 1 (6 items)
