Latest post 07-18-2010 11:21 AM by Doc. 2 replies.
Page 1 of 1 (3 items)
  • 07-18-2010 4:53 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Tvix 6600 and Beo4
    I have a Tvix 6600 which I operate with a Beo4 via the puc-list ( Tvix 6500).
    My problem is: I can't change the audio with my Beo 4 (by pressing "menu" and then the yellow button), but with the original Tvix remote I can (but this can only be done directly on the Tvix, which is in another room...)
    Does anyone recognize this / have a solution?
  • 07-18-2010 9:31 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Tvix 6600 and Beo4
    Hello Doc
    The remote control of the Tvix 6600 is one button diferent from the 6500 one. Audio on the 6500 is MUSIC on the 6600, and the Audio on the 6600 is a new button. The new PUC for the Tvix 6600 is already in the Service Tool, so you need an update of your Beovision PUC list.
    Regards
    Quim
  • 07-18-2010 11:21 AM In reply to
    • Doc
    • Posts 585
    Hello Quim,
    Thanks for your answer.
    Doc
