Latest post 06-28-2007 6:51 AM by Alex. 15 replies.
Page 1 of 1 (16 items)
  • 06-26-2007 2:28 AM
    Beosystem 3 and DTS
    I have recently upgraded to BS3 and when I was playing some DVDs today on my BC2...I noticed that I when I select DTS audio there was no sound!!! Dolby Digital worked fine but not DTS...I don't know why. This has not happened with my BS2 in the past...if anyone know what the problem is please let me know!!!
  • 06-26-2007 5:51 AM In reply to
    • Beonut
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    Re: Beosystem 3 and DTS
    Do you have an sp/dif cable beteen the dvd and the bs3? you need this to get dd5.1 or DTS, otherwise you will just be getting dolby prologic II.
    Have you checked on the bs3 what sound codec you are getting? to do this play a dvd then press - menu, options, sound, sound system and you will see the input sound and the output sound displayed.
    Regards
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
  • 06-26-2007 6:15 AM In reply to
    What's a sp/dif cable? I think the BC2 is connected to the BS3 via masterlink cable...
    The sound system display DTS 5.1 but no sound is coming out...
    Hmm....
  • 06-26-2007 6:30 AM In reply to
    If the dolby digital works, the SPDIF cable is ok. Does the system display Dolby Digital in the sound menu ?
    Curious: the active sound system is DTS, so the BS3 has "understood" that the stream is DTS...
    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
  • 06-26-2007 6:45 AM In reply to
    • Corvin
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    if the system is displaying the input format, what does it tell you the output format is?
  • 06-26-2007 7:27 AM In reply to
    • Beonut
    • Essex, UK
    • Posts 89
    Sounds a bit silly but are the speakers switched on? In my setup when I bring on my DVD1 the bs3 only brings on the center channel (ie speaker 1) apparently this is a prob with the dvd1 as i have one of the first versions. I then need to press speaker 5 to manually bring on all the speakers.
    Regards
    Peter
  • 06-26-2007 7:58 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    If the BeoSystem 3 and BeoCenter 2 are only connected via MasterLink, then it won't work. You need an SP/DIF cable going between the two. This takes the form of a standard 'phono' lead, but actually carries digital signals. DTS (or indeed any proper form of surround sound) cannot travel down MasterLink cable, or Scart.
     Weekly top artists:
  • 06-26-2007 9:52 AM In reply to
    Ok...so a bit of a correction...
    When I select DTS...the sound system input is "mono/stereo" and output is still "Dolby prologic IIx Movie speaker 5" but no sound....but when I select dolby digital the surround sound works fine...and I'm sure the speakers are on coz the green light on my BL5s are on and I have simply changed the audio by pressing the red button during playback...SO THIS IS THE PROBLEM! SPOT ON!!!!
    Regarding the sp/dif cable....I'm not sure whether it's there or not since everything was installed by B&O and hidden away...but I assumed it would be silly for them to not install that as well...No wonder the surround sound is not sounding as good as I thought...I'll let my installer know ASAP!
  • 06-26-2007 11:49 AM In reply to
    And make certain that your S/PDIF Coaxial Digital Audio cable is 75Ohms, with RCA at both ends.
  • 06-26-2007 10:48 PM In reply to
    So where does the spdif cable plug into on the BS3? There's so many AV source...2-6...The BC 2 is connected to the masterlink socket on the BS3...but what about the spdif?
  • 06-27-2007 1:46 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    conect to the digital in on a free input, then go to setup and tell the BS3 that this input is conected to a BC2
  • 06-27-2007 7:11 AM In reply to
    • Beonut
    • Essex, UK
    • Posts 89
    On the same AV port as the Scart or other video inputs are connected to for the BC2.
    regards
    Peter
  • 06-27-2007 6:42 PM In reply to
    Thanks for everyone's response...I'll try to get this sorted asap...
    This might be a stupid question...I assume that Dolby Digital will give a better sound quality that dolby prologic...and DTS should be better than Dolby Digital (I know this is controversial to some)...
  • 06-27-2007 8:26 PM In reply to
    • Alex
    • Posts 2,990
    Yes, something like that! Big Smile
     Weekly top artists:
  • 06-28-2007 5:53 AM In reply to
    • Beonut
    • Essex, UK
    • Posts 89
    And if you either connect a Playstation 3 or a Blu-ray player by hdmi to the BS3 and play a blu-ray movie you will get Uncompressed PCM 5.1 sound which is even better (much much better) than the DTS you get from your DVD .
    Regards
    peter
  • 06-28-2007 6:51 AM In reply to
    • Alex
    • Posts 2,990
    Beonut:
    Regards
    peter
    Yes, it's pretty jaw droppingly good!
    You'll also be all set for all the future formats, such as 7.1 surround sound etc.. (where you have extra speakers behind you).
     Weekly top artists:
