Latest post 07-16-2010 11:48 PM by banangoc. 2 replies.
Page 1 of 1 (3 items)
  • 07-15-2010 9:34 PM
    "CODE" appears on BEOMASTER 4500 system
    Hi ALL,
    I have recently puchased a used BEOMASTER 4500 system, and when I went to power it up I noticed there was the word "CODE" appeared in the led panel. I could not do anything. I don't have a user manual which doesn't help, (unless someone could email me one?). Do I have to input the CODE before operate? Or did the last user setup the CODE and forgot to inform me. cassette decks so you can record tape to tape.
    Thanks in advance.
    Banangoc
  • 07-16-2010 4:35 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: "CODE" appears on BEOMASTER 4500 system
    Hi & welcome to Beoworld.
    It sounds like the internal battery might need replacing. See HERE which is for the Beocenter 9500 though the 4500 is a similar model. The battery will need to be soldered in.  Tons of service & user manuals are availabe from this website but you'll need to upgrade to a silver or gold member to gain access. Well worth it.
    SteveSmile
    If you think nobody cares, try missing a couple of payments.
  • 07-16-2010 11:48 PM In reply to
    Hi Steve
    Thank you so much for your early respond.
    I will try as the way you mentioned.
    Cheers,
    Phong
