Latest post 01-15-2011 2:16 PM by Leslie. 4 replies.
Page 1 of 1 (5 items)
  • 07-15-2010 7:24 PM
    Glass doors for an Overture
    I broke mine [:'(]
    If anyone has a pair lying around, please let me know how much including shipping to Australia.
    Thanks in advance
    My B&O: 2009 Catalogue and Pricelist
  • 08-01-2010 9:08 PM In reply to
    Re: Glass doors for an Overture
    no joy as yet.....
  • 01-15-2011 3:00 AM In reply to
    If you have the metal brackets that were attached to the tops and bottoms of each door, have you considered just going to your local glass shop and having them fabricated, then gluing on the brackets?
    Some of the brackets on the doors I had came off. I had to re-glue the brackets back to the glass. It was a straightforward process - Attached the brackets to the Beocenter, then applied glue to the flat surfaces on the brackets. Next I attached and positioned the doors so they were level to each other. Placing the Beocenter horizontally on its back was a good idea.
    It wouldn't be that much of a stretch to get the glass door replacements from your local glass shop. What do you think?
  • 01-15-2011 7:59 AM In reply to
    How much are they from an Aussie Dealer??
    Regards Graham
  • 01-15-2011 2:16 PM In reply to
    I can get them for 70 euro each, is that much?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
