Latest post 07-21-2010 2:26 AM by yachadm. 7 replies.
Page 1 of 1 (8 items)
  • 07-15-2010 10:50 AM
    • Dermot
    • Not Ranked
    • Joined on 07-15-2010
    • Posts 4
    CD player problems
    Anybody suffering the same problems as I am , My cd player [4300] has failed after only 1446 hours of use B&O disown itor to put it another way it has cost me 21 p per CD EXCLUDING  original capital cost
    cost to repair £314.05
    Anybody else had a similar experience ?
     Let me know
    Message to B&O you sell high price goods which it is not unreasonable to expect will deliver long and reliable service My Experience is that this is rubbishas mine has failed after only 1446 hours and requires £314 to get it to work B&O have REFUSED to mitigate this . BE WARNED
  • 07-15-2010 11:18 AM In reply to
    Re: CD player problems
    Dermot:
    My cd player [4300]
    4300? Perhaps 3300 (80's) or 3000 (00's) ...or is this a TYPE number?
    And what EXACTLY is wrong? Perhaps we can help -at least point you in the right direction.
    Welcome to BeoWorld!
    • B&o bottle opener
  • 07-15-2010 11:28 AM In reply to
    • Dermot
    • Not Ranked
    • Posts 4
    Sorry so angry after a month of getting clock readings and dealing with middlemen made a mistake with number which should read 3200 .
    Total of 1446 hours usage since new [ignoring standby] Cd starts and within a few seconds stops display says no cd  , naturally have tried cleaning and many different CDs some play up to 30 seconds then same
    Repairers [B&O]  say needs new CD mech cost £314 .09
    Approached supplier B&O who simply replied out of warranty , frankly for a piece of kit at these prices I would expect it to last at least as long as the £30 piece of kit which works perfectly after more than 10 years but clearly as long as B&O have your money they don't .
    AS you can tell no doubt I am extremly angry at what I can only at this moment describe as shoddy overpriced goods
    THanks for your time
  • 07-15-2010 11:39 AM In reply to
    • Dermot
    • Not Ranked
    • Posts 4
    Hi Jeff
    The wonders of this site meant that because I moved the window I could not return to window to add your name and my appreciation of your response which has brought more comfort than nearly 6 weeks now of dealing with the labarinthine B&O corporate system .
    regards
    Dermot
    p.s. have also tried all the obvious e.g. turning on and off as well as things mentioned above
  • 07-15-2010 11:44 AM In reply to
    Dermot,
    Did the B&O repairer actually see your unit and do some tests on it ?
    The Beosound 3200 has a large number of internal test routines which help to define a problem in some detail, did teh repairer run these tests ?
    Regards Keith....
  • 07-15-2010 12:03 PM In reply to
    • Dermot
    • Not Ranked
    • Posts 4
    Hi Kieth
    Yes they did , and after some time provided me with the internal clock data
    regards
    Dermot
  • 07-16-2010 1:02 PM In reply to
    Dermot - I sympathize with your plight. The laser in my car CD player has recently failed as well. In no way am I excusing B&O, but perhaps CD laser/mechanism manufacturers (Phillips, Sony and the like) shoulder a part of the blame for increasingly shoddy build quality. For parts obtained from external suppliers, B&O absolutely should insist on the best of the batch, but as recent forum complaints regarding "clouds" on the BeoVision 10-40's Samsung screens attest, their external quality control leaves much to be desired.
    Just FYI, the first "3200" model, the BeoCenter 2500, had a curvy lens mechanism that was famously frail. The straight mechanism of the later models is new and improved. But unfortunately for your case, not "improved" enough. Sad
    Leo
    BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
  • 07-21-2010 2:26 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi
    While I'm very familiar with all the old-style CD units - pre-7000 series, which have the Philips CDM2 or CDM4, I have never had a 3200 come into my lab.
    Can someone who knows this unit technically tell me exactly which CD transport is in the 3200?
    If it's a Philips CDM or Sony KSS, I can probably give some help here.
    Regards
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
