Latest post 12-30-2010 11:29 AM by quader. 11 replies.
Page 1 of 1 (12 items)
  • 07-15-2010 9:39 AM
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    2 centre Speakers
    Does anybody have one in the same room ?
    I have 2 viewing positions, one for TV and one for the Projector.
    My dealer is suggesting a separate centre speaker ceiling mounted for the projector to get the full benefit .
    Any suggestions would be great.
    Thanks in Advance
    Filed under:
  • 07-19-2010 3:50 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: 2 centre Speakers
    come on guys, has no one got a 7.1 setup for a projector
  • 07-19-2010 11:07 AM In reply to
    Nope Smile Just a projector and an electric screen, which lowers just in front of the BV5 (with ALT). Works very fine for me.
  • 07-20-2010 12:21 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    do you have a 7.1 setup ?
    Unfortunately I have to put the screen on a different wall to the tv and hence could end up with 2 speaker setups
  • 07-20-2010 3:16 PM In reply to
    No, I have just an ordinairy 5.1 setup Big Smile
    Is the projector in the same room as the tv-panel?
    The BS3 has the speakerrole option. Then you can give your speakers a different function in different setup's (roles). Your rear speaker can be assigned as front and left as right etcetera.
    As good as I can reveal from the manual, the BS3 has 8 powerlink connections. One (spare) could be used as a centre speaker in another role.
  • 07-21-2010 8:01 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Yes , My projector is in the same room, I am looking to purchase a  BV7 40 MK3 tv so that i can use the different roles for the speakers and my dealer is suggesting a second centre speaker for the projector.
    I tried doing the above before i realised that i need the bv7 mk3 as the bv7 32 does not have that facility.
  • 09-03-2010 9:12 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Got another centre speaker  with a passive connection ceiling mounted
    and the sound is fantastic , just waiting to try out the 7.1 setup with a decent Blueray or HD movie on the projector.
  • 12-14-2010 7:51 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    I now have 2 speaker setups with a different centre speaker for the projector.
    The problem i now have is that i have to increase the volume so that we can hear the dialogue but turn it down when there is some explosive action.
    Is there anything that can be done ?
  • 12-18-2010 5:24 PM In reply to
    I did an experiment connecting an older projector to my BV7-40 mkIII. I did it in the same room projecting to the opposite wall of the tv.
    I found that you indeed need a second center speaker. I was hoping the beosystem 3 could mix the centerchannel into the two frontchannels, but I did not seem possible.
    I too experience problems with the extreme dynamic range of movies. It makes it difficult to hear dialogue without turning up the volume.  In another room I have a non B&O 7.1 setup with an Onkyo Receiver. The onkyo has a setting for limiting the dynamic range so calm scenes are louder and the level of action scenes are lowered. It works very well.
    I'd love to see a feature like this in the Beosystem.
  • 12-20-2010 7:38 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Hi Kimchr
    Thanks for that.
    I was hoping that someone would have a solution/ suggestions for this.
    I am sure that not many people could have a projector and tv setup on the same wall.
  • 12-24-2010 2:04 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    it appears the sound is better on speaker 4 for both tv (5 speakers) and projector
    (7 speakers) setup. i hope someone can throw some light on this
  • 12-30-2010 11:29 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    common guys , any suggestions
