1st March February 2012
Latest post 10-10-2010 3:38 AM by Dillen. 75 replies.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
And the cardboard box can be opened. The original capacitors take up most of the room in the carton. The excess volume at the bottom of the carton is usually filled with wax, pitch and/or some tar-like substance. In this one it looks and feels like wax. It is a messy job but I was happy to see that I didn't have to empty the whole carton. The lower end, where I opened the carton, under the paper rolls that form the original capacitors, the room that is filled with wax will easily accomodate the two new high-voltage capacitors. This will be fairly easy and well worth the time.
Dillen
- Posts 5,008
The three leads were cut as long as possible, cleaned off wax etc. and put aside. The lower "compartment" was also cleaned as good as possible and a piece of thin carton was prepared to use as double insulation between the old paper roll capacitors still in the carton (you can see the round shape of the paper/foil rolls) and the new electrolytic ones to come.
The new capacitors are 22uF 400V 105degC types so will be perfect for this task.
Dillen
- Posts 5,008
A new black lead was prepared. I used a silicone covered type that is a closer visual match to the old lead than any PVC type. Not a lot of it will be visible anyways, but even that will look right. The leads were soldered to the new capacitors and shrink tubing fitted for insulation. They fit nicely with a snug squeeze as the carton is closed so will be held nicely in place and will never rattle around. A blob of hot melt glue will hold the new capacitors in place in any case.
Dillen
- Posts 5,008
In place.
Dillen
- Posts 5,008
New, safe components in perfect vintage look. I couldn't have wished for a better result. Now ready to mount back on the chassis and noone will be able to tell the difference.
Dillen
- Posts 5,008
It's always a difficult task to settle for a policy when repairing/restoring a set like this. Previous repairers simply replaced the original defective components with what they had available. They put in what was modern components at the time and never thought much about it.
I just rebuilt the large filter/reservoir capacitor box, striving for a strict keeping of the original appearance and I'm now in a situation where a good handful of capacitors need to be replaced under the chassis and the inevitable dillemas surface ... - Who will ever look in there ? - Is it important to keep an original appearance inside the set at all ? - Should I try to make the new caps look like the old ones did ? - Would it merely confuse a future repairer ? - Should I follow previous repairers footsteps and simply take out the old ones and fit modern caps ? - The set is now 70+ years old but should that be reason for a sudden change of repair policy ? - Should I go for a sensible compromise and keep the (through the rear cover) visible parts on top of the chassis original and allow modern components in below decks and eventually store the old components in a bag or similar inside the set ? - Will it ruin the sets history or will it just add to it ?
Rich
- Joined on 07-11-2010
- Orlando, Florida, USA
- Posts 1,089
Absolutely fascinating and a wonderful read.
Thanks, Martin.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Dillen:
I know what you mean with these dilemma's Martin.
If it was a piece of antique furniture then any restoration which resulted in a "renewal" of the item would indeed destroy everything that made it an antique in the first place. With this project I would probably disagree in that there is no real antique value in keeping what are basically consumables which are expected to eventually wear out & die. My personal opinion is that you should replace everything with whatever is the best modern equivalent & somehow try to add a record of the origianal spec's for any future restoration. No doubt this beauty will be due for more remedial work in 70 years time.
Whatever you do is going to be a compromise. The safe restoration of this is inevitably going to compromise the end results so I wouldn't let it worry you Martin. I strongly suspect that the next person who opens this is likely to be an offspring of yours
Chris.
ipaul
- Joined on 04-22-2007
- Posts 378
@Martin: yes, i know very well what you mean...overhere in NL i know some guys tend to totally fix the cabinet with new laquer or paint and indeed put new caps in old ones etc and in the end i guess the answer to this dillemma lies in what you want with the end result.
Because....in all fairness...is there a point in making it work at all ??
What i'm getting at (also having some of these oldies): if they eventually work than why or for what would one use them ?
It's all wavebands which are (almost) not used anymore and the sound is ''vintage'' but technically there's no point listening to an old radio while we have good stereos etc.
I mean, i think if i would have mine working they would be put back on display and probably rarely being used, so why bother...
But yeah, i can see the technical challenge, so don't get me wrong...everyone should do with such a thing whatever they feel is to their liking, but if you talk about ''preservation'' than maybe just leaving it as it is, is keeping it as close to the original...:):)...
It's just a thought....:)
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
ipaul:
I think there's merit in restoring these old sets. About three years ago I bought one of the very sets that Martin restored, in what I think was his first ever restoration thread on this forum. The set gets used several times a week to listen to the news on the AM wavelength here in the UK. Reception on this set is fantastic, and the warm sound that the valve amp produces cannot be bettered!!
I do know what you're saying, but perhaps you don't really see the point in having a collection of functioning items? The real pleasure for me is in not only having the sets on the shelf, but actually listening to them - I really get a huge kick out of it :)
Dillen
- Posts 5,008
Thanks for the inputs, guys. Greatly appreciated !
The radio is not mine. I was asked to make it work but that does not remove the dilemma. It just eliminates the choice of leaving it alone, which I probably wouldn't have done anyways if it was my own.
If it was a very rare and unique item, there would probably be more sense in leaving it well alone rather than replacing things. But along with the collectors value, that would also show a general interest in protecting an investment. This is not really the case here. Having said that; For a radio like this, it is my experience that a working example, held closely to original appearance will fetch more money if sold, than a non-working sold as-is.
Besides, I feel that a radio like this should work. You should be able to switch it on, let it warm up while your sunday morning coffee is brewed and then listen to Benny Goodmans 1938 Carnegie Hall Concert in glorious mono on the Medium Wave band with crackling and whistling as it comes while enjoying the family breakfast. Much more fun than just having it sitting on a shelf or behind glass somewhere, as John also suggests. Even if the source of the programme is a CD player connected to a local AM transmitter in another room of the house. Having said that, there are quite a few AM stations still to be heard. Far more than FM stations. If they are worth listening to is a different matter. Fishing notations, sea weather reports and "radio Moskva" (no offense intended) may not catch wide interest.
I have given it some thought and I think I will go with a solution that goes like this; Keep everything visible as original as possible. That is the exterior as well as the upper part of the chassis, that can be seen through the rear vent holes and when the back is removed. I will allow modern components underneath the chassis and I will fit whatever is needed to improve safety, a decent suppression capacitor and a mains fuse spring to mind. I will also document the work done to the set by me. A printed copy of this thread will follow the set, as will all old components that are removed. Seen with the radios "eyes", this will then be just another visit to the repairers to keep it going. The previous repairers already replaced a good handful of components anyways and it would be in thread with the history told by the set itself.
Dillen
- Posts 5,008
One thing is not smart with this set; It's not easy to test the chassis on the bench. The output transformer and speaker sits in the cabinet - that could be solved with a couple of long leads but the pushbutton station selector module is in there too and the cable connecting it to the chassis is very short to prevent noise/oscillation etc. and should not be extended for the very same reason(s). I had to dismount the mechanical pushbutton station selector module from the cabinet to allow for proper testing of the chassis on the bench. Not a huge problem and since the pushbutton mechanism seems to have seized up badly it had to come out anyways. The top button is depressed and does not release when other buttons are pressed which also prevents the others from latching in correctly.
Dillen
- Posts 5,008
The module is clearly stamped "Kø" for København (Copenhagen) which confirms that this set was meant for use in the eastern parts of Denmark, near Copenhagen.
Dillen
- Posts 5,008
Work progresses slowly, but I have managed to do a little: A close inspection revealed that there was nothing seriously wrong with the module, it was simply the lubricating grease on the pushbuttons that had dried and become solid. A few drops of acid-free oil was applied to the dry spots and the module was left to soak in the oil overnight. Next day, the whole mechanism functioned perfectly. An additional few drops of fresh oil was added for good measure and all that's left now is to clean the whole thing, particularly the buttons. The tap that sticks up in this photo is connected to the release mechanism. It is reachable from behind and pushing it sideways will release any button depressed from the front.
Friedmett
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
Has Dillen given up here?
Or just to busy?
Time for an update right?
Medogsfat
- Posts 4,045
Friedmett:
I very much doubt it!
Or just to busy?
Quite probably.
Patience is a virtue
Dillen
- Posts 5,008
Chris is right; - Absolutely not ! - Indeed ! - Long over due !
I've been busy with other things. Repairs from all over had started to pile up here and I had to attend some non-B&O related things too but work on this wonderful set has not ground to a halt. Not at all.
This set was born without a mains fuse (!) so I will have to add one. I am perfectly aware that this will break away from the original design and inside appearance but it is a matter of safety - for both the owner/user and the set itself - so I will not compromise here and it should be a fairly easy task to fit something below decks somewhere. At 220-240V about 1,6A would seem fine. The running power consumption is never that high, but we will have to take the warming up into account. The valve heater filaments and also the dial lamp have very low resistances when cold so the rush-in current could be a bit on the high side. A DC reading showed apprx 200 Ohms when cold so that gives apprx 1.2 Amperes at the moment of switching on. The rush-in current could actually be even higher, namely in case the set is switched on right after being switched off, i.e. while the valves are still warm, allowing an instant current flow to rush in and fill up the drained filter and reservoir capacitors through the still warm rectifier valve and further down through the also still conducting output valve to ground. I decided to go with a 1.6 Amps slow blow. Tests later on will (hopefully) show if the theory holds water.
I found a good place under the chassis to fit a fuse holder for a normal 5x20mm glass tube fuse. Right next to the rectifier valve, an empty and already threaded hole was available. Probably a hole that was originally used for holding the original output transformer but with the external transformer sitting at the bottom of the wooden chassis, this hole was now left unused. It is fairly close to where the mains lead enters the chassis and there is exactly room for the fuse holder underneath. Safe and fully reversible if need be. Very nice.
Photos will follow when time permits.
Dillen
- Posts 5,008
Now, everything is, if not fine and working, then at least safe to power up. Workbench cleared, voltmeter across the high-voltage rail for monitoring and the mains connected to a B&O RT12 variac. Switching on. Increasing mains voltage slowly. Watching as the mains current rises slowly. Dial lamp starting to glow. Up the voltage to about 100 Volts. Dial lamp now brighter. Up the voltage even further, now around 180V. The high-voltage rail starting to show some voltage, climbing as the rectifier warms up. Nice so far. Around this time the amperemeter on the variac started to react a bit more as the output valve also started to conduct current. That also caused an expected minor drop in the high voltage. Still good. Up the mains to the full 220V. The smell of warm dust coming now - to be expected. The speaker now starting to emit a very faint hum - also to be expected. High voltage now around 150 Volts. Where it stayed... A bit low for a voltage that is given in the service manual as 200 Volts. There may be other fault(s) that will eventually show but this voltage is wrong and the reason will have to be investigated. This low voltage will not allow for clean reception - actually I had no reception at all in this case and it will not allow the magic eye to glow either. The good thing is that the most basic functions seem to work and there were no flames, smoke, bangs or other nasty surprises.
Dillen
- Posts 5,008
There can be many reasons for the high voltage to remain low. - The output valve drawing a too high current is a typical fault, often caused by a leaking grid coupling capacitor. The capacitor in this set is a green Philips type. It measured fine when tested with a meter and it is of a type that I usually find very reliable. It will, nonetheless, be checked again. Components that measure fine with a multimeter at low voltages can sometimes change their characteristics when a high voltage is applied.
The reason could also be the rectifier. A loss of emission (worn valve) will see a low output from the valve.
So no worries, there's still some work to do.
Dillen
- Posts 5,008
A replacement rectifier valve provided a voltage much nearer to that mentioned in the service sheet but the set remained silent. If the volume was turned way up, a "pleasant" humming could be heard but nothing else on any waveband. A buzzing sound could be heard if the control grid of the output valve was touched with a screwdriver. This was a good sign and it told me that the output valve was working.
This set has a gramophone input. It is connected to the EBC3 (pre-amplifer) valve so makes for a nice amplifier test point. A B&O TG7 signal generator got connected to the gramophone input and I was rewarded with a nice sine sound, clean with no distortion and good sensitivity (volume). This was also good news in that it told me that the preamplifier-valve and -circuit was also working. Next step backwards was the EF5 IF amplifier and CCH2 frontend heptode/triode. Replacement valves were test-fitted but that brought no change.
Next step was voltage readings. Anode voltage(s) on a valve will tell a lot about the condition and behavior of a valve and its circuit. In this case, everything tallied pretty much with the noted voltages found in the service manual. The CCH2 doubles as mixer and oscillator and both anode voltages were fine. The anode voltage of the triode section was given as 90V and I had 86V so the local oscillator was clearly running. If it wasn't, the voltage here would typically have been considerably lower at maybe 10-15 Volts or even less.
I then set up a signal generator, programmed it to the sets IF frequency of 440KHz and injected a modulated 400Hz onto the control grids of the frontend valve and IF amplifier valve respectively. The sensitivity of the IF amplifier stage was given as 6-8mV and I had a nice and clear signal at just about 3mV so that stage was doing fine. The frontend, however, was a different matter; Sensitivity here was given as 100-150uV (microvolts) but I had to inject about 2mV (millivolts) to get an audible output. The magic eye remained dimly lit but frozen.
Next step would be to check the adjustments of the first IF coils, the ones working with the CCH2 valve.
With the signal generator connected, it was soon clear that the first IF section operated at 444KHZ. Not the world off from the correct 440KHz but easily enough to disturb proper operation and reception. It was adjusted down to factory specs and the set was tried again. A long antenna (about 5 meters of wire across the floor) and the set came up talking swedish, I had struck a gardening programme. What a nice surprise ! Well, it turned out to be the only station on the wavebands and it was a bit noisy but it was a result. The best so far and a sign that I was not too far from having a fully working Master 39K on the bench. The magic eye, however, was still frozen and I would expect a top notch set like this to perform much better.
Dillen
- Posts 5,008
OK, time to realign this thing, then. With an AM set like this, it's not very hard to reach a good alignment, even by ear. Basically, what you do is tune in to a good clean station and simply adjust the IF coils for maximum volume. This set has two sets of coils to adjust. It turned out, that even the coil(s) I adjusted earlier could be set better. That just goes to show how things can sometimes be a bit "flimsy" and goofy with these old machines. Anyway, the wavebands were now filled with stations. Particularly the Medium Wave band as expected. Experience has it that short wave is pretty quiet in my neck of the woods but still a few stations could be heard using a long antenna. But no AFC and no reaction from the magic eye.
I then decided to set up my own little AM transmitter. Programmed it to send at 850KHz, which is around the center of the MW range on this set. The transmitted signal came through with good volume and great sound. Even the AFC did something now. The magic eye, however, remained frozen.
I scrutinized the circuit for the magic eye, even replaced a couple of resistors but couldn't find anything wrong. I found an old handwritten note in a service manual, telling something about changing a resistor to a larger value for greater deflection on the eye. I tried it but it didn't change anything. I even tried a replacement magic eye with the same result. Like a cathode ray tube (CRT "picture tube") the magic eye has a surface covered by phosphor, that lights up when hit by an electron stream. This makes the eye glow green. And just like a CRT, a magic eye can also have burn-in marks (remember screen savers?). This particular magic eye has a well defined burn-in mark right at the exact same area where it lights up now. It looks as if it was never lit any higher so I lean more and more towards the theory that the previous owner, just like I, hadn't got an antenna strong enough to give any deflection on the eye. That could also explain the need for "greater deflection", as suggested by the hand-written note. Not having a similar known good set of the same type at hand, I am tempted to say that this is how it's made and it will take a very good and strong, possibly directional, antenna to give better results. Whatever, I had plenty of international stations, even on just a meter of wire. The tonecontrol proved to be a bit "muffled". A shot of contact cleaner and a little exercise cured this. A small amount of crackling when tuning. This comes from the large (open vanes) tuning capacitor, it can be considered normal and will, no doubt, cure itself with use. The set played all evening, good sound and good continuity. No drop-outs, cracks or whistles. Just a slight modulation hum which is normal when I use the local AM transmitter.
Dillen
- Posts 5,008
I haven't been updating this thread a lot recently. It doesn't mean that I haven't been working on the set, merely that I haven't had time to do the writing. The Master 39K is close to being ready as you can tell from my previous post. That is, I still have the magic eye issue but I simply cannot see why it doesn't react; The circuit matches the schematics, all voltages are spot on, all components and all other valves are good and a factory new magic eye makes no difference. I will have to deem this repair done but I will keep thinking about this issue until I find a similar working set to compare with. The owner reads this post and I've also email'ed him the status so he knows that I've been struggling with this.
When I haven't had a lot of time for writing it's basically because I have a nice selection of other repairs here too at present. I also have a life besides this hobby thing and just when I thought I couldn't get more busy, the Master 39K owner told me that he bought another set. I couldn't believe my eyes when I saw this ...
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
What a beauty, forget the life beside and get on with it.
Dillen:
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico
- Mexico city
- Posts 1,621
its just beautiful, Martin may I copy the pic for keepsake ??
RUDYV
- Joined on 07-31-2008
- Belgium
- Posts 52
WOW, what a beauty !!!
Unbelievable, a Master de luxe 38 K, NOS.
Still under waranty ?
I'm ready for it !!!!!!
Rudy
