I'm trying to figure out what beograms can be remotely operated by a Beomaster 2400. I'm looking at a Beogram 3403 and 3404. They look identical to the Beogram 2400, but would they work with the remote?
Never heard of a 3403 but the 3404 should be fine. Check it has a 7 pin DIN plug.
http://img.inkfrog.com/click_enlarge1.php?image=CONDUCTOR_HAT_018_006.jpg&username=AmaanahLLC&aid=140165016
Seems like it is 7 pin. So I guess good to go?
Looks fine - check it is fully working and that the cartridge is OK. These are very expensive to replace.
