Latest post 07-22-2010 11:42 AM by joeyboygolf. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • 07-22-2010 6:55 AM In reply to
    • AdamS
    • Not Ranked
    • Joined on 04-17-2007
    • South UK
    • Posts 72
    • Silver Member
    Re: mmmpff...
    joeyboygolf:
    However, you can check the coils before sending the cartridge. If you have access to a multimeter, measure the resistance across diagonal contact pins on the rear of the cartridge. Open or closed circuit indicates defective coils but a few ohms resistance indicates that the cartridge is OK.
    NO, NO NO!!
    Do NOT test a cartridge's continuity with a multimeter! Even though the meter operates at a low voltage, this is still enough to cause irreversible damage to the fine wire that makes up the coils.
    I would assume (or hope) that Axel has a suitably low voltage/current way of checking the coils on any cartridges he tests, but a standard multimeter is not suitable for the job.
  • 07-22-2010 11:42 AM In reply to
    Re: mmmpff...
    AdamS:
    joeyboygolf:
    NO, NO NO!!
    I new it wouldn't be long before someone would rubbish my methods, it has happened before.
    My DMM might be special (£20 from CPC) for all I know but it certainly has not ruined any cartridges as of the present time. Of the 30 or so cartridges that I have tested ,only 2 or 3 have failed and been consigned to the bin. The failures were known non workers.
    Axel has refurbed the rest and has not reported any problems.
    I have batches of 6 or so refurbed to their original spec and apart from one batch that went to Germany via Australia I have had no problems!
    I can only comment from direct experience.
    Regards Graham
