1st March February 2012
Latest post 07-22-2010 11:42 AM by joeyboygolf. 26 replies.
07-11-2010 2:50 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Just a bit overpriced.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
9 LEE:
i got one of those... for free!
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Just got a used MMC4 from Ebay a week ago. How much should I have paid?
No offense will be taken if you answer in the affirmative: were you guys calling me a chump two weeks ago when I bought it?
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Rich
- Posts 1,089
I paid the equivalent of 90 pounds and am happy with what I received. I don't have the means to examine the stylus or anything, but the sound is just fine. Next time I'm just going to buy a SoundSmith.
About 18 months ago, my 1 year-old had thought it might be fun to press down on the tonearm of my RX2 and rub the stylus back and forth on the platter. So, I have an MMC4 cartridge with cantilever and no stylus. I know SoundSmith won't touch this, but perhaps the German outfit would?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Axel will replace the entire cantilever anyway, so I guess it would be no problem if the coils are still OK (and if the cantilever is still there, I don't think the internals have been damaged).
Never happened to me, but I don't expect he'd charge anything if it can't be repaired, so you wouldn't have anything to lose. I'd always prefer this option over gambling on eBay, although you seem to have been lucky!
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Rich:
IAbout 18 months ago, my 1 year-old had thought it might be fun to press down on the tonearm of my RX2 and rub the stylus back and forth on the platter. So, I have an MMC4 cartridge with cantilever and no stylus.
I met a guy who was restoring an old Mini. He hand beated all of the panels and did a concourse restoration. Not long after it was all finished, his 1 or 2 year old wanted to be like daddy and work on the newly restored car. He beat all of the mint panels with a hammer!! The kid obviously wasn't old enough to know that what he was doing was wrong, he just did as he saw his dad doing...
My B&O: 2009 Catalogue and Pricelist
Rich
- Posts 1,089
tournedos:
Checked the web site and did use Google translator on some of the pages, but I did not see any info on sending in a cartridge (only a few refurbs for sail). The only German I know is my last name (Haffner, as in the Mozart serenade and symphony)....would it be bad form to email to "info" at his web site in English?
Rich
- Posts 1,089
jldmelb:
Rich:
He was only trying to help. My daughter, on the other hand, apparently prefers digital to analog.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Axel tests all cartridges for deficiencies in the coils before repairing. If the coils are u/s he does not proceed.
However, you can check the coils before sending the cartridge. If you have access to a multimeter, measure the resistance across diagonal contact pins on the rear of the cartridge. Open or closed circuit indicates defective coils but a few ohms resistance indicates that the cartridge is OK.
Axel has repaired around 20 cartridges for me, some MMC4 , some MMC2. Quite simply, he does a superb job at a much lower cost than the new Sound-smith cartridge.
j0hnbarker
- LS28/GB
- Posts 2,002
Graham
Is the MMC4 rebuild worth it in your opinion? My MMC4 is on its way out, and I'd like a replacement. What does the rebuilt MMC4 sound like compared to a normal MMC4? I ask because I have heard that SMMC4s can sound superior to standard MMC4 carts, so wondered where the rebuilt MMC4 that AXel offers would fit in this spectrum? Also, how much is the rebuild?
Ta.
John
Rich
- Posts 1,089
joeyboygolf:
Sigh. If I'm reading the schematic right, I have resistance across L & LG ("top" and "bottom" leads) but open circuit across R & RG ("side" leads).
I suppose it can't hurt to send it across the pond anyway, right?
Stonk
- Marlow, Bucks, UK
- Posts 1,688
j0hnbarker:
Graham
Ta.
John
John, THIS might assist in answering your question. Although it's not for the MMC4 I'm sure the results would be similar.
If you think nobody cares, try missing a couple of payments.
j0hnbarker
- LS28/GB
- Posts 2,002
Thanks chaps - think I might go down the rebuild route then...
joeyboygolf
- Posts 3,252
j0hnbarker:
Graham
Ta.
John
I have MMC4's and MMC2's rebuilt as near as possible to their original spec. I can't tell the difference in sound quality between the rebuilds and the originals and none of my customers have complained!
The rebuild for your MMC4 will cost 99 euros.
The SMMC4 sounds impressive when first auditioned but gets harsh and tiring on prolonged listening depending on the type of sound you prefer to hear. However, to be fair, there is not much in it. If I had not heard the originals then I would not have noticed or would simply adjust the tone controls!
The Axel rebuilds seem to retain that easy to listen to B&O sound.
joeyboygolf
- Posts 3,252
Rich:
joeyboygolf:
If it was mine then I would not bother sending it as it sounds like you have defective coils on one channel.
I check all my cartridges before sending (these were Axels instructions). If they display a fault like yours then I simply throw them in the bin.
Rich
- Posts 1,089
joeyboygolf:
Rich:
joeyboygolf:
Instead I think I'll send it up to Benny in Georgia. I'll be out a couple bucks and know for sure. Shame.
j0hnbarker
- LS28/GB
- Posts 2,002
joeyboygolf:
j0hnbarker:
Graham
Ta.
John
Thanks Graham - sage advice as ever. Think I'll go for the 99 Euro rebuild and see how I get on with it.
