Latest post 06-25-2007 5:08 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 06-25-2007 4:01 PM
    Avant DVD linked to LX4500
    Having just got an LX4500 - I'm now thinking of going the whole hog and buying an Avant DVD, but I have a couple of question:
     1) If I use the LX4500 in my bedroom and link it to the Avant and my BS3000 will DVD's and satellite play on the LX4500 in widescreen rather than 4:3 or is there a setting like there is on the sky box
    2) Do most of the Avant DVD's come with Sky+ as standard in the STBC or do I have to get an upgrade chip and how much would that be.
    3) Doe they come with Dolby boards as standard so that I can connect the BL4000 to it as I have done with the LX
    Any help would be much appreciated.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 06-25-2007 5:08 PM In reply to
    Re: Avant DVD linked to LX4500
    I use an LX6000 in exactly the same way. Assuming that the LX4500 works in much the same way as the 6000 (and I think it does):
    1. DVDs play in widescreen. Satellite seems to as well.
    2. Depends on the age - I bought mine new and it needed updating. I think they fitted mine for free as I was buying something else at the time.
    3. In the UK, yes. DTS came later - you can tell if it is fitted by the sticker on the back. Any software update comes with a new sticker!!
