mnemonick:
.. how far off is Beonet and how does this differ from the MasterLink Gateway, if at all?
The ML Gateway is, as it's name says, a gateway or an interface between the
"World of B&O" and the "World of Home Automatisation and Controlling" both
in your home and, if connected to the web, from outside.
The type of the cable used for the MasterLink network (ML or Cat7) is irrelevant
for the functions of the gateway.
But only a Cat7 installation has the resources needed in the digital future ...
mnemonick:
I'd really prefer the neatness of the new solution, from what I've managed to ascertain
thus far, with ML and PL over the same physical presentation.
Be careful what you wish for, you might get it....
If your are going to replace all ML and PL cables needed in a 7.2 Home Cinema
/Audio System /plus some spare cables for e.g. Internet/Videoserver/... and
want a fully centralised/structured layout you'll have to install 20 or even more
Cat7 cables from your living-room to the patchpanel in your tech-area ...
Dont get me wrong, I'm a fan of the new installation concept - but a lot of
sufficiently dimensioned cable conduits are required!
