silly problem which we cannot fathom, the 2400 works fine plugged into the BT master socket, but we now want to move the phone to the other side of the room, and the BT extension (10metres) cable reel that we bought to do this does not quite work properly.
We can make outgoing calls using the 2400, but when someone calls our number the 2400 does not ring - it seems that by using a bog standard cable reel extension that the ringer is not able to work on the 2400
I took the faceplate off the BT NTE and it has a big yellow capacitor, which is good because I think that is what provides the ringing, the cables inside the NTE box are wired to pins 2 and 5, again what I would expect, so I am bit foxed by this one !
