Yes, though with the price of 28" Avants falling rapidly, probably economically not worth it. One in the colour you want will probably be cheaper than the parts and labour to change your existing set. Of course you could just spray paint the one you have - lots of masking and some car spray paint means you would have a bespoke set!
