Latest post 01-11-2011 3:24 PM by rabble. 44 replies.
Page 1 of 2 (45 items) 1 2 Next >
  • 06-30-2010 2:58 PM
    • rabble
    • Not Ranked
    • Joined on 07-13-2007
    • Switzerland
    • Posts 75
    Beolab 5000 system
    I thought I would start a new post as the last one was pretty much on another subject.
    Again here are some pictures of my restoration work of the 2500 cubes and Beovox 5000 type 6223.
    Today I received Beomaster 5000 (tuner) which I must say is in fantastic condition. I don't know if it actually works as I don't have anything to hook it up to (yet). Does anyone know how to hook up the cable TV line to the antenna input; I've never saw this kind of connection?
    I also though that the tuning slider would be a bit more smooth (the wheel slides a lot and it requires quite some pressure to make it move) is this due to age and can something be done?
    Now I will probably have a long wait before I can find the Beolab 5000 and perhaps a suitable turntable. Maybe I'll go for a Thorens as they are quite easy to come by (even the old ones)
    P.s. Beosystem 7000 is still going fine.
    Cheers
    Andrew
    Andrew
  • 06-30-2010 3:10 PM In reply to
    Re: Beolab 5000 system
    Looks great! Nice wood pattern.
    • B&o bottle opener
  • 07-01-2010 3:14 PM In reply to
    • beobeo
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Spain
    • Posts 953
    How nice!
    How did you paint the cubes? i have a recently acquired pair and although in good condition, they may take a good dose of tender loving care.
    Gustavo
  • 07-02-2010 4:14 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Lot's of masking tape over the chrome and the B & O labels, and then four coats of black semi gloss spay paint.
    To do a proper job, you need to remove the grills and paint them seperatly, but there is the risk of damagimg the wood when you do this.
    Mine were damaged anyway, so I made the repair with plastic wood and lot's of sanding.
    Installing the grills is a bit of a pain as they needed to be glued in.
    Good luck
    Andrew
    Andrew
  • 07-02-2010 4:40 AM In reply to
    • beobeo
    • Spain
    • Posts 953
    Thanks Andrew,
    I shall post some pictures of the restoring works. Did you remove the tweeters? This is the part I'm more concerned about as they seem so fragile.
    Gustavo
  • 07-03-2010 3:35 PM In reply to
    Good work Andrew and welcome to the 5000 Club ;-)
    Did you change the capacitors also? Here is the tread of my first restoring work: http://forum.beoworld.org/forums/t/32946.aspx
    BTW. I've send my Beolab 5000 to Frede Kristensen (Classic Audio) for restoring... He's the expert for this outstanding amp.
    Best regards
    D
    P.S. Where are you located in Switzerland?
  • 07-04-2010 6:10 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    I just taped around them
    good luck
    Andrew
    Andrew
  • 07-04-2010 6:13 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    wow, great job, much better that my amateur attempt
    live in Wädenswil
    Andrew
  • 07-04-2010 8:24 PM In reply to
    WOW!! Both of your cubes look outstanding!!
    I'd love to have mine in the same condition, but I'm too scared to touch them...
    As one of the guys here at B&O Service said: 'Even if they don't work, you'll keep them because they look so good'
    My B&O: 2009 Catalogue and Pricelist
  • 07-05-2010 2:41 PM In reply to
    rabble:
    Thanks, but you're work is also quite good!
    rabble:
    live in Wädenswil
    That's close to Zurich... ;-) Never listened the sound of the Beovox 5000. did you bought it in Switzerland? Which model do you own MK I, MK II or MK III?
    Best regards
  • 07-05-2010 2:46 PM In reply to
    jldmelb:
    Just do it! ;-)
    jldmelb:
    Agree! They look really stylish with a high WAF... ;-) The cubes are worth for restoring and they improve the soundstage from some beovox 2400, 3000, 4000 and 5000!
  • 07-06-2010 6:49 PM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    They are Mk I.
    I found them at the local "Broki" (second hand, flea market) paid 50 Sfr.
    The teak was in pretty bad shape, but that was easier to repair than the cubes (their were no dent's or pieces of teak missing). Lot's of sanding and steel wool and then teak Oil.
    I have them hooked up to a Beosystem 7000 and at low volumes they are a bit week, but that could probably be fixed by changing the capacitors.
    Most of the time I have the volume up a bit so for me the sound is quite good. (even better when the volume is up)
    Andrew
  • 07-08-2010 5:01 PM In reply to
    rabble:
    They are Mk I.
    Nice, i've heard that the MK I Version is the best soundwise...
    rabble:
    That's a really good price. You're lucky!
    rabble:
    Changing the capacitors will definitive improve the sound... Remember, the capacitors are 40+ years!!! Maybe Martin (Dillen) can support you.
  • 07-09-2010 11:45 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    is it a difficult job?
    Andrew
  • 07-11-2010 3:08 PM In reply to
    rabble:
    It was not really a difficult job by my Beovox 2400 and it was my first soldering work... I think the Beovox 5000 has a more complex cross-over network. Some people here recommend good quality caps from Jantzen http://www.jantzen-audio.com/html/caps.html
    Good Luck!
  • 07-22-2010 5:02 PM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    I can't beieve my luck, I thought it would take a year to find this.
    http://www.ricardo.ch/kaufen/audio-tv-und-video/stereoanlagen/bang-und-olufsen/beolab-5000/v/an613235818/
    If I could find a beogram 1202 at a reasonable price and good condition, I'll be all set.
    Andrew
    Andrew
  • 07-23-2010 6:01 AM In reply to
    Congratulations. Looks like a very well treated and maintained unit!
    You'll be very pleased when you switch it on.
  • 07-23-2010 11:37 AM In reply to
    The mark 3 5000s probably sound the best, the mark 1s are the best made and the mark 2s are the weakest. With 2500s,I would use mark 1s.
  • 07-24-2010 4:17 PM In reply to
    Hi Andrew,
    Congratulations to your Beolab 5000. Your system is almost complete! ;-)
    This thread will be interesting for you: http://forum.beoworld.org/forums/p/27975/218998.aspx#218998
    rabble:
    In my opinion is the Beogram 400x the better choice (design and soundwise) for your Beolab 5000 system...
    If you are looking for originality then would be the Beogram 1000, the Thorens Beogram 3000 (perfect match) or the Beogram 1700 your choice.
    Best regards
    D
  • 09-20-2010 2:58 PM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Well I finally found a Turntable to go with my system. I managed to win on ebay a Beogram 3000 for only £59.00.
    No it's not the thorens.
    I guess it should be called MKII?
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130431142190&ssPageName=ADME:B:EOIBSA:GB:1123#ht_522wt_1139
    Seems that it needs a new needle and from what I gather, this might cost more than the Beogram. I guess that I'll have to look around some more.
    Andrew
    Andrew
  • 09-20-2010 3:49 PM In reply to
    The 3000 is a good deck - the best deck with an SP cartridge made by B&O. You might be able to get the cartridge repaired by Axel.
  • 09-21-2010 3:54 PM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Hi everyone, today I decided to take a stab at trying to fix the tuner.
    Moving the slider was quite difficult. Frede gave me some good advice to make sure that I removed the string before taking off the front cover. (I would regret this later). After removing what seemed to be about 100 screws of various sizes and having bits fall out from who knows where, I had everything open. It reminded me of when I took apart my first clock, the whole thing exploded and I still did not know how it worked.
    Anyways, unfortunately everything inside looked like the day it was made, so after a bit of tinkering, out came the WD-40 and a cotton Swab and I started dabiing at all of the moving parts. Low and behold after a few minutes and a very black swab, everything freed up and now the slider moves like it was new.
    Now it was time to put everything back togethor and as you can guess, re-attaching the string was anything but staright forward. I actually did not manage to get it back the way it was, but it should hold. (This part took me about 45 min.)
    I still don't know how to attach an antenna as the connection for it is foreign to me. Does anyone know if there is an adapter for the cable Tv connection?
    Andrew
  • 09-26-2010 5:19 AM In reply to
    • classic
    • Top 500 Contributor
    • Venø - Struer / Denmark
    • Posts 224
    Please look at this link http://beolab.dk/BM5000-I-uk.htm
    So depending of you cable conecction you must use 75 ohm or 300ohm input. I am here using the 75ohm input. The local input is for use if your antenna signal is very powerfull - it actually are there because of the Danish broadcasting 'Danmarks Radio' who used the Beomaster for quality monitor for many years.
    The hard job could be to get the plug.
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 09-26-2010 6:53 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Hi Frede, you are right the plug is the problem.
    Any idea where I can get a picture of it so that I know what I am looking for?
    If I can't get the plug, is it possible to simply push in the bare wires?
    Cheers
    Andrew
    Andrew
  • 09-26-2010 8:20 AM In reply to
    Hello Frede - do you have similar interior photos of the Beolab 5000?
