Latest post 07-01-2010 6:50 PM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 06-30-2010 9:50 AM
    • Vifa
    • Not Ranked
    • Joined on 05-24-2008
    • Posts 64
    New pickup - replacement for MMC2 ?
    My MMC2 pickup is oblique, as you can see in the attached picture. I think I read once on this forum that the MMC2 is no longer in production. So what should I consider for a replacement ?
    I am unsure whether or not my current pickup will do any damage to my records, so to be safe I have decided to buy a new pickup - but which one ? Any recommendations ? Which one is the best ?
    Best Regards
    Vifa
    MMC2 Pickup
  • 06-30-2010 10:02 AM In reply to
    Re: New pickup - replacement for MMC2 ?
    You have two choices:
    1. Get your one repaired - Axel repaired one of my MMC2s which had a cantilever snapped off - works perfectly and uses what must be original parts.
    2. Get a Soundsmith replacement SMMC2.
    The repaired one will sound like an MMC2 - the Soundsmith one will be brighter and sound more dynamic. Some think this is fatiguing, others like it.
  • 06-30-2010 4:37 PM In reply to
    • Vifa
    • Not Ranked
    • Posts 64
    Thanks, then I think I will consider getteing mine repaired :) Meanwhile, should I avoid using my turntable with this pickup - can the pickup do any damage ?
  • 07-01-2010 10:55 AM In reply to
    If it sounds OK, it should be fine though I confess I would not use it on my records.
  • 07-01-2010 3:11 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Vifa:
    ... can the pickup do any damage ?
    counter question: even a perfectly aligned pick up causes record wear ... what will a misaligned one do?
  • 07-01-2010 3:19 PM In reply to
    Actually I don't think that is the problem. I would be more worried that the suspension will collapse completely and the guard will then scratch the record.
  • 07-01-2010 6:50 PM In reply to
    I would get it repaired by Axel and retain the easy to listen to MMC2 sound.
    The soundsmith sound is very good on initial hearing but does get a bit harsh on extended listening. Just my opinion (revised)!
    Regards Graham
