Latest post 09-27-2007 1:41 AM by Peter. 7 replies.
Page 1 of 1 (8 items)
  • 06-25-2007 11:03 AM
    Beolink 7000 One Way ?
    Hi !
    I'll use the Beolink 7000 with an Avant an with a Beosound 9000.
    I read on an other forum that it's possible to edit the Beolink 7000 in order to use it one way.
    Have anyone the describtion to do that ? And also to move back into twoway communication ?
    Thanks !
     Mike
  • 06-25-2007 11:36 AM In reply to
    Re: Beolink 7000 One Way ?
    The Beolink 7000 sets itself to either one way or two way when you add components to the system page. So to set it up, remove all that is already on there and then add and store the components you want to use. Each component that is added is tested by the Beolink 7000 by sending out a signal. If it gets a reply, it is two way. If it gets no reply, the 7000 stores it as one way. It is a rotten one way remote by the way!! The Beo4 and forthcoming Beo5 are far superior with the components you mention.
  • 06-25-2007 4:49 PM In reply to
    Dear Peter,
    thanks for your very fast answer ! I'll try it. I was fascinated of the Beolink 7000 an bought it, it's a little bit freaky... I often heard that the BL 7000 isn't very funny using one way... mmmh.... B&O should think about introducing the two way communication for all parts...
    Thanks again from Bitburg
    Mike
  • 06-25-2007 5:12 PM In reply to
    I will now intrigue you! I get two way information from my Beocenter 2 and Avant DVD on my BL7000 - sort of!!
  • 06-25-2007 6:29 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Tell me more!!!!Confused
    Andy T.
    Poor me, never win owt!
  • 07-17-2007 3:01 PM In reply to
    • Tibor
    • Not Ranked
    • Joined on 04-16-2007
    • Budapest, Hungary
    • Posts 36
    Beolink 7000 two way communication with BeoCenter 2
    Could you please give us the details how to get the two way communication with BeoCenter 2 ? Thanks !
    Next step: BV7-40 or BS3 with projector ?
  • 09-26-2007 9:45 PM In reply to
    Re: Beolink 7000 two way communication with BeoCenter 2
    I have a Beocenter 2 (2007) and want to know if I can use with a Beolink 7000 and if so, which version of the BL 7000 will I need to buy.
  • 09-27-2007 1:41 AM In reply to
    You can, but it will only work in one way and this makes it an inferior Beolink 1000. I would suggest that the new Beo5 is quite a bit more useful.
