Nice!!
http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
mr anders son,
Looks very nice!
With which software did you make the GUI look so great? (I recently got myself a tvix 6600)
wow ! so cool !!
I hope Philippe can work similar wonders for us and the LinkPlayer
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
I can't use my iPad to post on Beoworld though :(
wasn't there a trick for getting iPhones to update?
maybe the same trick is needed for iPads?
edit 1:
[ from memory it was a Beoworld configuration setting ... but I might be wrong ... try a search or wait for someone whose memory is tad better than mine! ]
edit 2:
I did it for you anyway anyway:
KingOfSnake: I can't use my iPad to post on Beoworld though :(
Try this... a BeoWorld setting. Read the whole thread as there is another option to try in it... Pick which works best for you!
OK, thanks.
Can you please tell me about the second picture of the iPAD; I have downloaded TViXie but don't recognize the screen on my iPhone?
