Latest post 06-26-2010 12:46 PM by Doc. 4 replies.
Page 1 of 1 (5 items)
  • 06-26-2010 4:25 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Audio volume Tvix 6600 with BV7 mk3
    A few days ago I've got myself a Tvix 6600 installed. It's connected by HDMI only, to my BV7 mk3.
    I have to turn up the audio volume to very loud (>70) to hear the same as a TV-signal (volume of 50).
    Can this be changed; settings Tvix or BV7 ?
  • 06-26-2010 4:38 AM In reply to
    Re: Audio volume Tvix 6600 with BV7 mk3
    Hi
    I have turned up the volume on the TVIX to MAX (using the Tvix remote), and then it works just fine for me.
    There is something about B&O.....
  • 06-26-2010 5:00 AM In reply to
    • Doc
    • Posts 585
    Hi Beolin,
    Do you have the tvix 6600 as well?
    Don't you control it via the puc-list / beo-remote?
  • 06-26-2010 8:28 AM In reply to
    Yes I do, and I control the Tvix via PUC, but you can increase the volume on the Tvix (no PUC code for that). I did that, as I before had to turn up the BV7 volume to 50-60, and now I have the volume at 30-40 on the BV7.
  • 06-26-2010 12:46 PM In reply to
    • Doc
    • Posts 585
    Beolin,
    Do you use a beo4 or beo5? With my beo4 I can't seem to skip a movie to another chapter, or go to a "DVD's" menu to change subtitle or other settings....
