1st March February 2012
Latest post 07-03-2010 6:30 AM by KingOfSnake. 17 replies.
06-25-2010 7:05 PM
Divingnut
- Joined on 06-01-2007
- Posts 1
Lower a BeoVision 10-40 on motorised base
In the market for the BeoVision 10-40, however I don't like the way the TV sits 10cm high on the base. it just looks wrong
Does anyone know how easy it would be to shorten or lower the pole so the TV sits just suspended off the base, just as the gorgeous BeoVision 5 did.
I've photoshopped how I think it should look..
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Re: Lower a BeoVision 10-40 on motorised base
Divingnut:
... looks gorgeous but ...
the limiting factor for lowering will be the required thread engagement to safely attach the pole to the base plate and the space needed for the connection plugs!
Having modified a table stand BV7-32 / no BLB 7.1 in a similar way I remember it has been a lot of time and effort
- You'll have to dismantle the pole to protect the cable during cutting - Very probably you'll have to modify the cable feedthrough to get enough space for the connection plugs
You'll need a metal-craftman or precision tools to - cut the pole precisely - cut the threads
good luck !
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Divingnut:
This is excellent, it looks alot better. I do not understand why B&O did not use this length stand for BV10. Future update? Come on how much would it actually cost them to cut the pole 15cm??
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
I'm surprised that people like the idea of reverting back to the low stance. B&O have been visually cheating the physical reality of televisions for years now. Making the Avant look like it was a flat screen hanging on the wall, for example. The BeoVision 10 is genuinely as thin and visually light as B&O have long deigned their TVs to look and I was delighted to see that they emphasized this by letting it float off the ground. To my eye, lowering it to nearly the base of the stand is going in the opposite direction and making a very slim television look large and heavy.
To each their own I suppose.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
david707
- Joined on 04-20-2007
- Posts 295
I replaced an LX5500 with an Avant 32 and much prefer the landscape or 16:9 look of the LX. Room ceiling height is a determining factor. The Avant would IMHO still have the same 'picture on the wall' effect if it were 100mm lower yet be much less bulky and dominant in the room. The BV10-40 is far better proportioned although I can understand why many would still prefer a lower stance depending on their room dimensions and TV position in relation to other furniture etc. Compatible adjustable stands would be a useful addition.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
TripEnglish:The BeoVision 10 is genuinely as thin and visually light as B&O have long deigned their TVs to look and I was delighted to see that they emphasized this by letting it float off the ground.
I can understand that...
OTH, I always thought the BV5/9 looked like a painting in an artist's studio -slung down low like they are. They are (were) distinct.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I liked the idea of lowering the 10 until I read your comments. Now I realize, for the reason you stated, I much prefer it as it is made.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
TripEnglish
- America
- Posts 1,595
burantek:
You're going soft old man!
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Not sure how being 10cm off the floor emphasises it's thinness. If it did they could've done it with the BV5 to mask it's thickness!
I prefer the "close to the floor" look, it looks as if it were meant as opposed to just being on a stand.
TripEnglish
- America
- Posts 1,595
Puncher:
I think that it emphasized the lightness rather than the thinness.
Puncher
- Posts 9,588
TripEnglish:
Puncher:
Still prefer the "close to the floor" look - purposeful, rather than on a genric "TV stand".
Dave
- Posts 2,328
Puncher:
Precisely. Close to the floor (judging only by the photo) gives it a stately prescence, it looks cheap / flimsy imho, on its standard stand. Lets make it happen, it should at least be an option... STB brackets??
leogenghis
- Joined on 12-08-2008
- Posts 169
B&O should have made the height of the floor stand adjustable in
the first place, or offered two height options. Both heights satisfy
different people and look good. I emailed Gavin Sykes at STB last November and here was his response:
"We will probably not make a lower floor stand, B&O would
not like us to play with their latest concept and to be honest I love it on the
stand. In fact, I have it on the stand in all three of My B&O
stores."
However, it is possible that if more people email him about this he may change his mind! Unfortunately, even if he comes out with a lower version it'll be hard to justify the purchase since I've already paid $$$ for my stand.
Leo
BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
Peter
- Joined on 02-12-2007
- Posts 9,572
I actually agree with both sides. The stand does make the TV seem to float and it looks great - but you can then see the cables which is not so great.
Mr10Percent
- Joined on 04-16-2007
- In Transit
- Posts 441
Looking at photographs of the rear of the BV10, it should be quite straight forward to make 2 x 6mm thick spacer bars for this with 4 holes in each.
Think a shape like this with two holes counter-sunk one way, two holes the other. Easy.
leogenghis
- Posts 169
Hey, sounds like a good idea! No cutting to the stand itself - I like it. My only concern would be the tilt mechanism. The tilt is not motorised and holds its angle by friction. Adding spacer bars might disrupt the balance so the angle won't hold. Unless it can be locked into place.
Leo
KingOfSnake
- Joined on 02-07-2008
- Posts 359
I agree, the TV looks far better in BV5/BV9 stance.
Page 1 of 1 (18 items)
