Latest post 06-25-2010 5:21 PM by Hardwriter. 4 replies.
Page 1 of 1 (5 items)
  • 06-24-2010 5:31 PM
    Beolink converter with BC6-26 and BC9300
    I am a complete novice when it comes to connecting B&O equipment so I hope someone will be kind enough to help me out with an answer to this query.
    I've just acquired a Beolink converter 1611 to connect my Beocenter 9300 (MCL) music system to my Beocenter 6-26 TV (ML). I wish to put the sound from the TV through the two speaker sets connected at present to the music system. I have yet to get the necessary cables to make the connections, which is where the question comes in - I want to get the right lengths to avoid paying for several metres of surplus copper!
    I seem to remember a previous post referring to an audio delay when connecting a B&O music system to a B&O LCD TV - something to do with digital processing delays - but I can't locate it now.
    My question is, if I connect the TV to the music system with the speakers connected directly to the music system, will I experience an audio delay? If so, will that be in both directions - I mean audio via the TV speakers and TV sound via the audio system? And will it make any difference if I run the speakers directly from the TV? Or am I worrying unnecessarily?
    Any input from some of the technicians here would be very much appreciated. Thanks
  • 06-25-2010 9:05 AM In reply to
    Re: Beolink converter with BC6-26 and BC9300
    There shouldn't be any delay assuming its all in the same room.
    It would be a ML cable from the TV to the 1611 and then a five pin cable from the 1611 to the Audio Aux port on the 9300.
    Probably better to run the speakers from the TV if it has a Dolby surround module etc.
    Then just a case of configuring each device to send the sound one way or the other.
    Train Hard - Run Fast - Hit to Kill!!!
  • 06-25-2010 12:02 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Large48:
    ... the 1611 and then a five pin cable from the 1611 to the Audio Aux port on the 9300.
    NO! You'll need a 7pin "DataLink" cable from 1611 to Audio Aux/TV on the 9300 - a standard 5 pin DIN can't
    transmit the data required for system intergration!
    Large48:
    YES! If you your speakers are active ones you should connect them to the PL sockets of your TV or DS
    module and set V-/A-Option to 2/0.
  • 06-25-2010 12:19 PM In reply to
    I never could remember if its a 5 or 7 pin cable I need................... :-)
  • 06-25-2010 5:21 PM In reply to
    Vienna and Large48, Thanks for the advice. Much appreciated.
