Latest post 02-09-2012 10:45 AM by Jeff. 16 replies.
Page 1 of 1 (17 items)
  • 06-25-2007 8:00 AM
    Remote Mains Switch Type 4001
    Does anyone have a user manual for the remote mains switch type 4001?
  • 06-30-2007 2:38 AM In reply to
    Re: Remote Mains Switch Type 4001
    I think it will be a challenge to find a user manual for your remote mains switch, I certainly don't have one and I have not seen one on the Beoworld site. What is your exact problem with it ?
    Regards Keith....
  • 06-30-2007 6:59 AM In reply to
    I don't know how to connect to beomasters or beosounds.
  • 07-01-2007 8:32 PM In reply to
    I currently have two of these switches in operation (one of them in a link room.) I have changed the "activation" plug to an 8-pin din plug (power link) -- I hooked the ground wire to pin 2 and the +5v to pin 4 (PowerLink speaker on)  and plugged them into an "extra" powerlink socket. (In my case, I am only using a single powerlink for the speakers, then from the first speaker to the second.)
    Be sure to test the box first, however. I bought two and one of them had a bad relay. Replaced it and it's fine now. To test, just plug everything in. The outlet should go on and off using the switch in the front.
    Ric
  • 07-03-2007 3:45 AM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    A few points about these:
     1) They work natively only with the BeoCenter 9000 and BeoMaster 5000.  Anything newer requires an (inexpensive) adaptor:
    http://retail1.bang-olufsen.dk/Communityaccess.asp?Produkt=6270517
     2) They provide non-polarized AC switching -- whatever you plug into the back has to have equal-size prongs, not the newer polarized kind.  Good luck finding much that will fit there nowadays.
  • 07-03-2007 4:50 AM In reply to
    beomasterdc:
    Found one! I have a type 4002 complete with instructions!!!!
    The instructions are for type 4001 and 4002 so if you PM me your preferred email address I'll scan it and send you a copy.
    Regards Graham
  • 07-03-2007 8:35 AM In reply to
    Can you send me a copy too and I will put it on site. A picture of it would be useful as well I suppose! If you feel like writing a product article, please do! Laughing
  • 07-03-2007 11:13 AM In reply to
    You have an email Peter
    Regards Graham
  • 07-03-2007 11:41 AM In reply to
    Think it may have been too big but that might just be to my Blackberry! I'll see when I get home!!
  • 07-03-2007 2:43 PM In reply to
    No, it is fine! I'll add this to the site.
  • 07-03-2007 5:09 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Just noticed there is not a picture of one in products section as yet. Maybe someone who has one could e-mail Peter a picture.
    CraigBig Smile
  • 07-04-2007 2:05 AM In reply to
    This is the best picture I can find
    Mains switch
    Regards Keith....
  • 07-04-2007 2:16 AM In reply to
    Well done Keith, this is much better than the miserable attempts that I sent in!
    Regards Graham
  • 07-04-2007 3:12 AM In reply to
    Nothing wrong with yours! Keith's is from the catalogue. Yours are entirely original!! And available for all to see here! (Lee has tidied it a little!) Laughing
    The manual is available in the manual section in pdf form!
  • 07-04-2007 3:55 AM In reply to
    Well done Lee, only recogniseable as mine because of the pin sharp focus!Laughing I really must get that ******* camera sorted. It's a Fujifilm S3500 but Brett has lost the manual.Angry
    I'll try and download one and see if I can fix the problem. The camera is out of warranty so it's probably knackered!
    Regards Graham
  • 09-09-2011 10:50 AM In reply to
    • Xprtiz
    • Not Ranked
    • Joined on 09-09-2011
    • Posts 1
    Could you please send me a copy as well ?
    Greatly appreciated
    Jocelyn Marquis
    xprtiz@me.com
  • 02-09-2012 10:45 AM In reply to
    • Jeff
    • Not Ranked
    • Joined on 03-01-2010
    • USA
    • Posts 48
    • Gold Member
    Wondering about failure modes for these. I have two of these that used to work, now they don't seem to work at all. I had them plugged into one of the Powerlink plugs on both my AV7000 to control an amp for the rear channels, and on my Beosound 9000 to turn on the amp that drives the rest of the house speakers.
    Neither seem to work, if you turn them to "Timer Off" they work, but won't switch on automatically. I've just resetup my audio system after it being in disarray for a couple of years (yeah, procrastination).
    I assume it's the relay that's bonkers. I've seen them on ebay, but believe that it's pointless to buy another as it will probably have the same issues. Anyone know the best way to troubleshoot and repair these? Thanks!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
