Latest post 06-24-2010 1:19 PM by solderon29. 3 replies.
Page 1 of 1 (4 items)
  • 06-24-2010 4:38 AM
    2 Pin Power Extension Gang / Lead
    Here's hoping number 3......................
    A recent 5500 stack has arrived all with European 2 Pin plugs on the end of the power leads.
    Instead of cutting these off and putting UK plugs on the end I was hoping that someone might have an official B&O (the grey one) 4 socket power gang that perhaps I could use.
    If I can't get hold of the B&O one I may have to resort to using a 'normal' one, something that to buy in the UK seems to be expensive.
    Does anyone have one?
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 06-24-2010 7:19 AM In reply to
    Re: 2 Pin Power Extension Gang / Lead
    Guy,
    I think I have one but I'm at work at the moment.  I'll have a look tonight and PM you
    Cleve
  • 06-24-2010 8:58 AM In reply to
    Most B&O items were supplied with the two pin plug and stacking systems were supplied with the 4 way EU extension lead.
    You can get converters to fit on the two pin plug to convert them to UK 3 pin type.
    http://www.powerconnections.co.uk/convert_eurotouk.htm
    Regards Graham
  • 06-24-2010 1:19 PM In reply to
    I've got one Guy,next time you're in the 'hood,or I'll post.
    Regards,
    Nick
