He means the input/output marked equaliser. This is a line in and out socket. The problem with using this is that it will remove the power amp[lifier in the 6500 so you will lose your outputs. I don't know what happens to the power link connections.
The 5500 has a similar system but has RCA sockets connected by a pair of metal hoops. I actually run my headphone amplifier from this and then run the output back again.
