Latest post 06-21-2010 4:42 AM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 06-20-2010 12:38 PM
    • BeoBoo
    • Not Ranked
    • Joined on 06-16-2010
    • Petaluma, CA
    • Posts 4
    Cartridge Adapter For RX Turntable
    I've a RX turntable with a MMC5 cartridge that I'd like to convert to accept other B&O cartridges or brands of cartridges, preferably p-mount. Is there an adapter available to do this, if so, where can it be obtained? Thank you for your help!
  • 06-20-2010 1:57 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Cartridge Adapter For RX Turntable
    No such adaptor due to the lightweight nature of the MMC* cartridges. B&O did produce an adaptor to enable these cartridges to be used on other turntables but not the other way round I'm afraid.
    Chris.
  • 06-20-2010 10:18 PM In reply to
    • BeoBoo
    • Not Ranked
    • Petaluma, CA
    • Posts 4
    Dear Chris,
    Thank you for getting back to me on this. It looks like I'll have to send the cartridge out for a new cantilever, I understand buying a used or old stock MMC is risky. Perhaps I can fabricate an adapter such as a square plastic holder having male MMC sized pins on one side with female p-mount receptacle pins on the other.
    Regards, Gabriel
  • 06-21-2010 4:42 AM In reply to
    • Medogsfat
    • Posts 4,045
    The problem with mounting anything other than a MMC* cartrifge will be setting the tracking weight. You will need to fashion something appprox' the same weight as the cartridge which won't be easy but good luck if you have a goSmile
    Chris.
    PS, welcome to Beoworld.
