Latest post 10-16-2010 11:31 AM by Beo_freak. 12 replies.
Page 1 of 1 (13 items)
  • 06-19-2010 5:58 AM
    Beovision 5 problem
    Hi everyone,
    I've got a problem with my Beovision 5. It produces a high pitch humming noise, especially when it displays very bright images.
    The more white there's in the picture, the louder the noise. It's not the speakers, but on the back of the television.
    I've been told that it's the chassis that needs to be replaced, is this possible? If so, is there anyone who knows if this will be an expensive repair? Is it something I can do by myself? I only bought it recently, so it feels bad that it doesn't work the way it should.
    I hope there are some people out there who can help me out!!
    Thanks in advance!
    Nicolas
  • 06-19-2010 8:50 AM In reply to
    Re: Beovision 5 problem
    Nicolas,
    The problem you are describing is called "Vision on Sound" in the TV industry which does not happen very often in modern TV's but was very common in years gone by.
    The cause is normally to be found in the IF stage where the combine sound and vision signal is split into its seperate components. You did not say, but I am assuming that this does NOT happen when using a STB. If it also happens with a STB, then the fault will be very different.
    Unfortunately or fortunately depending how you look at it, all the IF stage these days are usually in one chip and therefore changing that chip and/or its associated components would almost certainly resolve the issue. HOWEVER many years ago B&O introduced field replacement units only, meaning component parts are are not changed by dealers only modules or chassis.
    So, the short answer is the module or chassis will need to be changed by the B&O dealer if the problem is not using a STB. If you recently purchased this TV as a pre-owned unit without warranty, then it could be quite expensive.
    Please confirm if this problem does NOT happen when using a STB and only happens with an internal DVB module ?
    Regards Keith....
  • 06-19-2010 9:25 AM In reply to
    Hi Keith,
    Thanks a lot for your reaction!
    My problem does not only happen with an internal DVB module, but also when using a STB or another source. (B&O DVD1).
    Nicolas
  • 06-20-2010 2:35 PM In reply to
    Anyone
  • 06-29-2010 10:58 AM In reply to
    Who can help me with this one?
    Thanks in advance!
  • 06-29-2010 11:40 AM In reply to
    It could be the powersupply in your BeoVision 5. Bright pictures take up a lot of power, the powersupply is working hardest with these pictures and sometimes you hear the powersupply.
  • 06-30-2010 4:31 AM In reply to
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    I have experienced (and still suffer from) the exact same problem with my MK1 BV5. I replaced the chassi appr. 3 years ago due to a faulty ML contact so I can confirm that this did not solve the problem. Have also heard about the potential power supply problem but since my technician let me know that the only solution would be to replace the screen I decided I would have to live with it. Would be very interesting to know if there is a more economic way to cure this problem. Seriously considering a second hand BV9 in the future but they are still a bit too pricy (at least in Sweden there te few ones that are for sale are announced for around 12-13.000 EUR).
    Please keep us updated.
    Regards,
    Emil
    Inflagrante
  • 06-30-2010 4:56 PM In reply to
    Hi Emil,
    Thanks for sharing your experience! I'm glad to hear that I'm not the only one who has this problem. I will keep you updated if an economic solution pops up!
    Best regards,
    Nicolas
  • 07-02-2010 2:31 AM In reply to
    Hi guys
    I can tell you guys that your not alone :-)
    I'm also thinking about a BV9 or maybe the BV7-55"
    Cheers
    Anders
    Regards Anders
  • 07-02-2010 11:48 AM In reply to
    Hi there Anders,
    Thanks for your reaction and welcome to the club ;-)
    Still, if anyone who reads this has a solution, please, let us know!!
    Nicolas
  • 07-02-2010 12:11 PM In reply to
    Beo_freak:
    Hi there Anders,
    Nicolas
    Yeah sorry that I didn't have a solution for that problem! other than turn it off! Looks still as beautiful you know Stick out tongue
    Regards Anders
  • 07-05-2010 4:46 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Indeed a really beautiful set the BV5. As regards the BV9 it seems they are for sale a bit more often in Denmark than in Sweden. And better prices as well. Also noticed that there are two sets at Lifestyle for sale even if do not know if the shipping costs and costs for changing the inbuilt DVB-T makes them a very economic choice...
    Have not stumbled in into any second hand BV7-55 still though. And I do think I find it a little bit to big, at least if you - as I do - prefer the BL7-6 before the 7-4.
    Inflagrante
  • 10-16-2010 11:31 AM In reply to
    I still have this problem...
    The humming noise is located at the back of the tv. When you're behind it, in the top corner on the right...
    Who has got a solution to get this sorted?
    Thanks!
    Beo_freak
