Latest post 06-18-2010 6:57 AM by Noah. 13 replies.
Page 1 of 1 (14 items)
  • 06-13-2010 9:59 AM
    • Noah
    • Top 500 Contributor
    • Joined on 12-16-2008
    • Switzerland
    • Posts 120
    • Silver Member
    Beocord 6500 problem
    Hi guys
    I have a problem with my Beocord 6500. It seems that it is playing only on one channel. The sound of a tape is just coming from the right speaker! I first thought my left speaker has gone but they are bouth playing with CD and Radio.
    Has anybody a advice what I can do to fix this fault?
    Regards, Noah.
    Filed under: ,
  • 06-13-2010 10:10 AM In reply to
    Re: Beocord 6500 problem
    are the heads of the tapedeck clean? if not use alcohol and some real soft tissue to clean them.
  • 06-13-2010 10:11 AM In reply to
    • a11mcr
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Hi Noah, check the connectios in the 7 pin din cable first (maybe a loose wire) if these are ok plug you cd into the tape socket and see if that plays ok if not then it sounds like the socket soldered joints?
    Kind Regards, Mark
  • 06-13-2010 10:33 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    I cleaned it with a cassette head cleaner tape. Don't know actualy if it worked!Confused
    Can I take film cleaner too?
  • 06-13-2010 10:36 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Hi Mark. Thank you for your advice.
    Do you mean that I should plug the CD into the Tape socket of the Beomaster? How do I check if there is a fault in the 7-pin sockdt of the Beocord?
    Regards.
  • 06-13-2010 1:30 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Hi Noah yes just pulg the cd into the tape socket if it plays on both left and right the fault lies with the tape deck or cable.
    Kind Regards, Mark
  • 06-13-2010 3:12 PM In reply to
    • Yoyo
    • Not Ranked
    • Joined on 05-10-2009
    • Belgium
    • Posts 25
    Hi Noah,
    Check with the idea of Mark.
    What may also happen that a cable cut at the rotary heads
    Hebergement gratuit d image et photo
    You can verify this by making a short-circuiting, with a metal paper clip, the two channels on the output plug heads.
    For that we open the unit (2 screws to unscrewed not completly on the back)
    MAKE the opération with connector PLUGGED (see photo 2)
    If you have the sound on two channels with the paper clip, the cable outlet of the head is cut, see your local Technical Service.
    Avant c'était pas mal, aussi bien qu'aujourd'hui, mais en plus vieux Embarrassed
  • 06-14-2010 3:34 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Okay. Thank you guys for your hints!
    I tried to play the CD over the Tape socket but there was no sound! So I plugged my second Beocord into TAPE and TV/AUX and the sound was just fine. So there must be a problem with the tape deck, don't you think?
    Today I will open the Beocord that won't work on bouth channels to looks what Yoyo described!
    Has anybody an idea if the tape deck of the Beocenter 9000 or 9500 will fit into a Beocord 6500??
    Regards, Noah.
  • 06-14-2010 4:16 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Yoyo! So succsess with your procedure! Don't know if I made it right...but I think there must be something wrong with the head!
  • 06-14-2010 4:24 AM In reply to
    • Yoyo
    • Not Ranked
    • Belgium
    • Posts 25
    Yes one of the cables from the head is certainly cut !
    It is best to replace the head
    Anyway, it should be removed to see if you can resolder the cable.
    Cables are cut because the head rotate (auto-reverse mode).
    good luck !!
  • 06-14-2010 2:14 PM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Has anybody an idea how the compatability is between the Beocord 6500 tape deck and the one of a Beocenter 9000 and/or 9500? Is it possible to exchange them?
    Regards, Noah.
  • 06-16-2010 3:31 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Anyone?Confused
  • 06-17-2010 1:40 PM In reply to
    • Yoyo
    • Not Ranked
    • Belgium
    • Posts 25
    Hi Noah,
    Excuses me for the late reply.
    The 6500 are 2 type of mechanism deck: with two motors (first version) and one motor (last version).
    First, see your 6500 if 1 or 2 motors (if 2 motors, one is up and other is back). If one motor, the deck looks like this image (sorry, i'm not a great artiste)
    deck 6500 version 2
    The Beocenter 9000 is a version with 2 motors, the cables and plugs is not same for Beocord 6500. But the head is same.
    I do not know for BeoCenter 9500, I have not the technical documentation. But the same rotary head is used and
    I think if the versions are the same like your 6500 (one or two motors), it should go, except perhaps fixing problems and cable/plug lenght.
  • 06-18-2010 6:57 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Hey Yoyo
    Thank you for your drawing. I could not do it better!Big Smile
    The Cord 6500 with the faulty head is a later version I think. So you guess the 9500 tape deck could be compatible with a 6500? Can you imagine that they made different decks for the models they produced back then?
    Could be worth to try it...
    Best regards, Noah.
