1st March February 2012
Latest post 11-03-2010 9:48 AM by Large48. 71 replies.
Jon
- Joined on 03-05-2009
- Posts 138
Re: Why do people put down B&O sound
*Sigh*, this is the problem with internet discussions - you tell yourself you're not going to argue anymore, and then the other person says something to draw you back in.
I can accept what you're saying about me; I don't know anything, I'm the uneducated one, blah, blah, blah, whatever.Honestly, it's not an ego thing here.
But, now it's just about the EQ thing and the math behind it. You want headroom for transients, but designs like B&O's stuff are using that potential headroom for bass extension.
Of course the EQ will be applied at line-level. That's a no-brainer. It would be that way whether the system is active, powered, or passive. Even if the amp had a ski-slope freq. response, the principle for power usage would be the same.
If, in the BL8000 for example, it took 10dB of EQ at 45Hz to get the -10dB @ 48Hz freq. response stated by B&O, and you use all 150w to get a certain SPL at 45Hz, then in the upper bass/low mids where there isn't any EQ being applied, you would really have only 15 watts to work with. Do the math yourself, I promise it works out!
Anyway, what do I know? I'm stupid.
I'm done. Won't say another word in this thread, I promise.
Jon
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified:
Electrified
- Joined on 10-05-2009
- Greater Copenhagen, Denmark
- Posts 404
Jon:
It was you who made the statement that my posts made the B&O enthusiasts look uneducated. It's a bit late playing the victim card.
Jon: But, now it's just about the EQ thing and the math behind it. You want headroom for transients, but designs like B&O's stuff are using that potential headroom for bass extension.
They are using some of the headroom to up the bass, but far from to the extent you claim. So far from it, that I don't even find it funny you're trying to make the argument that a 40W amp driving passive speakers has more headroom than the BL5s. Seriously, do the math again. And this time take into account that all the drivers aren't amplified by a single amp. No, there are several amps in there. So not only is it done at line level, the various bandwidths are amplified separately. The net result is an enourmous amount of headroom. Massive, in fact.
Jon:
Yes, it works out the same way the logic of Erasmus Montanus works out: A rock cannot fly, Mother cannot fly. Ergo: Mother is a rock.
Jon:
I'm crossing my fingers.
Oh, and John (Barker),
Very funny
soundproof
- Posts 2,340
Sorry, Electrified. I don't buy your position on this at all. You have arrived at a conclusion as to what constitutes good sound, to you, and now you're mystified that the entire world isn't on board with you. That's something you'll never experience - listening preferences are simply too diverse.
You may also actually find reading and comprehending what your interlocutors are writing useful - rather than just setting up straw man arguments that serve your point-of-view.
Yes, BL5s measure well, if not, I wouldn't own a pair. But B&O have done absolutely nothing to explain how best to use them, and most owners of BL5s use them incorrectly, if the goal is to make their acoustic lenses "shine." And when the lenses are used correctly, through engaging side wall reflections, then the speakers do not measure according to the ideals used to evaluate speakers these days. That doesn't worry me at all - though I do know, from direct experience, that it did worry B&O in Struer.
But I find the manner in which you "argue" very unengaging, and think I'll tune out for now.
Cheers.
yachadm
- Joined on 06-24-2007
- Jerusalem, Israel
- Posts 687
There is a lot of black and white in this, and also a lot of grey.
When I am so adamant that I say that I prefer my 40-year-old B&O system to a new digital system, well, that's he grey speaking. But to get to that stage, there was a lot of black-and-white involved.
To restore that 40 year-old system, there was a lot of methodical and measureable research involved. That research had nothing to do with - "let's try this part, and see how it sounds". No, that would not have satisfied me. I wanted the most accurate reproduction of sound that that EXISTING 40 year-old design would give me. Why, because I believe that B&O's 40 year-old design was the best design of its time, a design that has proven itself to hold up over time.
So, I set up a representative power supply on a breadboard, with lots of sockets, all connected to my most trustworthy measuring equipment - my fully restored Tektronix 2465B (also all analog) and started inserting many different types of capacitors to determine their effect on the quality of the power-rail signal. I can assure you all that there is a measurable black-and-white difference between one or other capacitor of equal values.
At the end of this black-and-white test, my choice of capacitor for the power-rail path was quite clear. There is no competition for the Nichicon HE and Panasonic FM, with the Panasonic EB a close second.
And those are the power-rail capacitors I use in all my restorations. That was an easy black-and-white decision.
In spite of that, I still see "garbage" capacitors being used in many high-end equipment today, which gives me the impression that their designers either don't care, or their recommendations were shot down by the bean-counters. Which further reduces what little respect I may have had for those companies.
Choosing an audio-signal path capacitor is much more difficult - it's very much a grey, subjective area. Here, I rely very much on recommendations and on my own grey, subjective listening tests. And, believe it or not, I'm not fully convinced that boutique audio capacitors really, really make a difference! But again, my ears are over 50 years old, and influenced by over 20 years of jet-engine noise, so maybe there is a difference which I can't hear.
However, once again, I am absolutely disgusted when I open up a multi-thousand pound machine and I see a no-name Chinese capacitor of a single series in every capacitor position (both power and audio-signal).
It is as if the company is blurting out to the customer without shame - "You see Mr Customer, we know you don't know sh-t - we use garbage, and we are still able to con you into buying our product." And that attitude is more prevalent with today's digital age, than ever before in the history of sound equipment.
And, BTW, I'm not impressed when I see plain-Jane Samwha capacitors all over B&O's new equipment. There's enough profit margin in each machine to do a lot, lot better, and get a more reliable and better sounding product to boot.
I'd like to see, just once, a manufacturer ad opening up the cover to full and unrestricted criticism, and inviting the customer to ask questions, and actually responding honestly.
Now that would be a company I could respect, and I'd bet the sales figures would reflect that respect as well.
So, grey, and black-and-white - they both have a place. At the end of the day, what really counts is what the manufacturer chooses to do with the information he has acquired thorough painstaking research, if he cared enough to bother to do any research at all.
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
Electrified
- Posts 404
soundproof: Sorry, Electrified. I don't buy your position on this at all. You have arrived at a conclusion as to what constitutes good sound, to you, and now you're mystified that the entire world isn't on board with you. That's something you'll never experience - listening preferences are simply too diverse.
So, no measurements or objective facts it is then. Sure, let's all follow the lowest common denominator, simply because we can't agree. Excellent way of dealing with things.
soundproof: You may also actually find reading and comprehending what your interlocutors are writing useful - rather than just setting up straw man arguments that serve your point-of-view.
You may need to reread my posts and try to comprehend what is actually said, instead of relying on audiophilic myths.
soundproof: Yes, BL5s measure well, if not, I wouldn't own a pair. But B&O have done absolutely nothing to explain how best to use them, and most owners of BL5s use them incorrectly, if the goal is to make their acoustic lenses "shine."
What the hell bearing has whether or not B&O has explained to you how to set up your speakers to do with whether or not they're good speakers, has loads of headroom, and are very, very accurate? They're more forgiving than most speakers when it comes to placement, but they are speakers, so a little effort is needed, of course. But again, I can't see why that should have any bearing on anything we have discussed so far, to be honest.
soundproof:
As it rightfully should. The problem with giving hard advice on the placement of speakers is that every room is different. That doesn't mean, naturally, that it doesn't matter, but that there is no one solution for everyone.
soundproof:
My "manner" in which I argue, where I cut up the posts is a very traditional way of arguing. It's one of the best ways to check premises and validity of arguments, and that is the reason I use it. If it were all about what I like and not liked, then you'd have a point. Since that is not the case, I will continue to cut up people's posts to counter the strawmen, Ad Hominems, appeals to popularity and other logical fallacies, the myths, the ignorance, and what else we have, thank you very much.
yachadm
- Jerusalem, Israel
- Posts 687
I just wanted to add, that some manufacturers are quite receptive to constructive criticism of their products.
I have had an excellent relationship with Asus, being one of the first Asus dealers in Israel, and in those early years, we had direct aceess to the Asus Engineering personnel at Taiwan HQ. The relationship has stayed very healthy over the years.
About a year ago, Asus released a motherboard with the highest-quality Panasonic capacitors to-date. I was very surprised to see that, because, while I was accustomed to seeing relatively high-quality components on their boards, that was the first time I'd seen a "digital" company take the step of quality without cost considerations.
I was suitably impressed to the degree that I fired off a complimentary email to the head engineer in Taiwan, complimenting him on his choice.
He wrote back to me, stating that it was nice to hear when customers appreciate their efforts, especially when most customers wouldn't even know enough to notice the difference.
Now, I know that most manufacturers would not appreciate customer "interference" in their choice of components, and that's their problem. But here was a very positive example of the manufacturer "sensing" what would be good for the customer, is also good for them.
Menahem
Electrified
- Posts 404
That ASUS-story reminds me of Lenovo and their Thinkpad developers. They asked us users on their blog if we would be interested in a Thinkpad netbook. Of course, quite a few of us were, but we were all adament that it should have a matt screen, not compromising on the keyboard, have enough connections and a trackpoint (and various other things such as being reasonably fast etc.). They listened and now we have the Thinkpad X100e:
http://shop.lenovo.com/us/landing_pages/thinkpad/2010/X100e
Not quite the same as your capacitator-stuff, but it's nice to have a company (division) listen to their customers - both the ones already in the fold and prospective ones.
AdamS
- Joined on 04-17-2007
- South UK
- Posts 72
Doctor:
It could be that there are some B&O fans at Hi-Fi World! A certain Mr T. Jarman writes for them as does one of our own - Mr Adam Smith. I am still waiting for the write up of the 8000 system - I think they are waiting until they all have one before extolling its virtues and putting the price up! I also await the 4400 article - I am happy to lend them a 4401!
You've hit the nail on the head, Peter - editor David Price has vetoed it from the magazine until he has one but as Tim and I both have 8000 systems, we're finding this very frustrating! What's especially amusing is that I pointed David in the direction of the 8000 system that I now own but when he had done nothing after a week, I grabbed it myself!
Also, following an earlier comment about Linn and Naim, I have the BM8000 which I love, but my main amplifier is a Naim Supernait, which I also love, so what does that say about me? On second, thoughts, perhaps I don't want to know....
chartz
- Joined on 07-20-2009
- Burgundy
- Posts 984
Hi Adam,
On what forum can we find David?
We have a few words to tell him...
We DEMAND a Hi-Fi world publication of systems 6000 (mine: Beogram 8000/Beocord 9000/Beomaster 6000/Beovox MC120.2) and 8000!!
yachadm
- Jerusalem, Israel
- Posts 687
And what exactly makes you think that your system is better than my BM3400, BG6000 (Quad no less - ho, ho, ho) with 4 Beovox S45's?
We'll confuse the poor fellow - he'll not want to review anything younger than 20 years-old again
Menahem
chartz
- Burgundy
- Posts 984
Nice one, Menahem!
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Electrified:
evman140: What really drives me up a wall is the arrogance that people have with Bose. From both sales persons and owners. They seem to think Bose is the answer to everything. "Oh, you have Yamaha + JBL? Well I have Bose..."
Hmm, that sounds like someone going "Oh, you have a Cannondale + Shimano XLR? Well, I have a bike from Tesco ....". They're ignorant, there's not much you can do about that sort of people.
Yes, call me arrogant, elitist, geeky, or whatever - chances are you're right
I wish I knew more about cycles!
I'm bumping this early Bose topic because I went into the local dealer yesterday and now I want to make an exception to my initial comment. I met one of the most polite and well spoken gentleman in there, I asked about the 901s and took all my questions very seriously. He gave me a demo and I have to say, not bad...
I wish they wore name tags so I could remember his name!
Large48
- Joined on 06-24-2008
- London
- Posts 455
It is comparable to bringing along a CAT-Scanner on a date. - LMFAO
For those of us that aren't audio wizards AND are partially deaf, its a case of if you like it buy it and if you don't walk away.
Part of these technical arguments continue the Geek view ala CPU and FSB arguments!
BUT it is good to see such passion for B&O after all these years.
Train Hard - Run Fast - Hit to Kill!!!
yachadm
- Jerusalem, Israel
- Posts 687
Actually, it's not at all about the numbers - at this stage of the game, anyway.
My tiny little BM3400 amp is only capable of 20W RMS x4. A mere pittance by today's standards....
But what a sound it is capable of! So, it is definitely a case of "If you like it, buy it..."
Now, behind the scenes, the hundreds of hours of research and soldering and loving attention to detail which it took to get that system to that fully-restored stage, well, that's another story.
But I'm not here to impress anyone with my technical skills (not many listeners care about that anyway, and that's OK), just here to impress you all with the end result of the sound. And that sound will make many modern systems ashamed of themselves. And I'm not ashamed of that!
WOW! B&O passion - it's all about the sound! Just trust your ears - Forget about the numbers!
Menahem
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Large48:
There you are, and the passion is there for years to come.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Electrified
- Posts 404
Not to rehash the argument, but someone being actual partial deaf has more benefits of a system with less distortion than one with excellent hearing.
Numbers may be geeky, but they're much better than "feelings" and "beliefs".
Electrified
- Posts 404
Er, I figured I needed to explain my last post:
The amplitude response of ears, as shown by Fletcher/Munsen, is
concentrated in the 300-3kHz band, which is where the fundamentals of our voice
is. The top end is where intelligibility comes in. The top end is
where it matters because it is here we're able to differentiate what is
being said/heard. A 20 watt amp clipping and general distortion in this
top end makes everything less intelligible - even more so for people
being partially deaf.
We tell how loud something is by when the
ear begins to distort. When being partially deaf, this distortion will
happen early/at a lower level. If you feed a partially deaf person a
distorted signal to begin with, you're not helping him. On the contrary,
he's in more need of high fidelity (in the literal sense) than the
rest of us.
A clipping amp with passive speakers is not the way
to go if you want to get as little distortion and clipping as possible.
The "geeky" numbers and measurements tells us that
Edit: Spelling ...
Electrified
- Posts 404
Sort of. It throughly depends what you have: The mentioned 20W amp into passive speakers is a bad choice.
Active speakers with big enough amps not to clip and distort(too much) is the way to go.
When your hearing goes, it becomes difficult to sit in a noisy place and hear what the person across the table is saying. Some of that is of course the way the brain works: We're able to"tune out" the noise and thus focus on the person we're talking to, but without the upper bands, we're in trouble. Hearing aids help in this respect as they up the signal-to-noise ratio in the bands where you need it.
Large48
- London
- Posts 455
I guess the main difference I have been shown (thank you to a certain Mr T. J.) is that the older speakers MS150 on the back of various beomasters have a more 'rounded' sound compared to newer passives and this only seems to be that the midrange of older passives is more designed / engineered than the newer ones.
Mind you I just like to turn the bass up..... ;-)
