eck:
Phoned a B&O dealer and he has quoted £690.00 plus installation for the DVT-T module ,is it really worth it I wonder!
Eck
If you are going to pay that much I would enquire about the availibility of FreeviewHD compatible version.
FreeviewHD PVR's seem to be ~£150.
btw - I said earlier that CH4HD would arrive later, it's actually broadcasting already.
You should also check freeviewHD availibility in your area, just because you're going digital doesn't mean you will get HD - you can check your postcode HERE
edit - I've just tried my own postcode and it says I won't get it until 2012 - wonder what I'm watching now!
It's because I'm inbetween two transmitters, one is up and running the other won't broadcast HD until 2012. The checker isn't clever enough to tell me about the other transmitter.
