I've just picked up a pair of Rosewood S40s for £4 from my local tip.  The cabinets, with some of the nicest figured veneer I've seen in a while, are very restorable and the fabric, although dirty, is unbroken.  As usual, though, the bass drivers' foam surrounds have gone.
However, I have a spare pair of 20cm/8inch bass units taken from a pair of S45.2s.  Would it be possible to use these in the S40s, and if so, are there are particular issues or concerns I should be aware of?  I appreciate the S45.2 cabinets are deeper, but I suspect that was to accommodate the phase-link unit rather than the 8" bass driver
Cleve
