Latest post 08-02-2011 2:24 AM by VW411. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • 04-20-2011 10:28 AM In reply to
    • VW411
    • Not Ranked
    • Joined on 03-02-2009
    • Lahti, Finland
    • Posts 27
    Re: Just bought BM1900
    Thanks for the replies guys! I'll check the areas you pointed out and tell how the BM reacted.
  • 08-01-2011 3:22 AM In reply to
    • VW411
    • Not Ranked
    • Lahti, Finland
    • Posts 27
    I've found out what was causing the problems in the left/right channels. It was the balance potentiometer i had repaired earlier. I hadn't had pinched the potentiometer assembly back together tight enough, so there was some loose movement in it.
    Does anyone have a picture of a wall mounting bracket for a BM 1900? I'd like to place the BM to my livingroom wall, but i'm not sure how to do it yet... I was thinkg i'd hang the BM directly to the wall so it would hang exactly vertical. But i've understood the brackets (atleast for a BM 4500) will position the BM slightly canted. If i hang the BM vertical will the lid stay slightly open all the time?
  • 08-01-2011 4:10 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    There's no bracket.
    The Beomaster 1900 (and 2400) is already prepared for wallmounting so
    you just need two screws in the wall.
  • 08-02-2011 2:24 AM In reply to
    • VW411
    • Not Ranked
    • Lahti, Finland
    • Posts 27
    Great to hear! Thanks!
