Latest post 06-24-2007 5:10 PM by Peter. 10 replies.
Page 1 of 1 (11 items)
  • 06-24-2007 1:00 PM
    help please - BS 3000 problem
    Hi Forum,
    I have a problem and before taking my kit to the local B&O dealer thought I would pick your collective brains if I may. My BS3000 is connected to my Avant via an ML cable. The Avant set up as Option 2  and the BS as Option 0, hnece the Avant controls the BS and the sound for the BS is via the avant (i have no other speakers).
    For some reason the BS has simply stopped working, the red light is on, but the doors do not open automatically and pressing buttons on the BS or the beo4 has no effect at all. The cd or radio do not work.  I have tried resetting the options but this does not seem to make any differnce, the BS does not seem to respond at all (i.e the confirmation double flash of the power light does not happen)
     so does anyone have any ideas ? any suggestions at all would be most welcome
    mant thanks keith
    Filed under:
  • 06-24-2007 1:10 PM In reply to
    Re: help please - BS 3000 problem
    Have you tried switching it all off at the mains, leave for a minute and switch back on again?
    Regards Graham
  • 06-24-2007 1:12 PM In reply to
    If you have not already, unplug it from the mains and also unplug the ML socket. Leave for 5 minutes and then try plugging it in unconnected. Set it to option 1 and see if it now works. You can sometimes get a block on Masterlink which just stops something from working.
    The other thought is a PIN code issue - does yours have a pin code?
  • 06-24-2007 1:22 PM In reply to
    Thanks Guys i will give that a try. I must admit i did not know PIN code was in use and if it is i would not know what it was.
  • 06-24-2007 1:43 PM In reply to
    Thankyou guys and especially Peter. it worked !
  • 06-24-2007 1:57 PM In reply to
    Probably a Masterlink issue. Mine did this when I got my Beolink PC2. The TV keeps a log of the errors but you need to go into the service menu and it is all gobbledygook to me!
  • 06-24-2007 2:54 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Peter and Graham, Are you two competing to see who can answer first?Geeked
    That's twice you've done it this afternoon!
    BTW, glad to see his problem sorted, gives you a warm glow, doesn't it?
    Andy T.
    Poor me, never win owt!
  • 06-24-2007 2:58 PM In reply to
    Why do you think we asked Graham to be a technical adviser! He really knows his stuff. And he is getting quicker! Laughing Our posts seem to be at the same time - I am scanning at the same time so I am posting slowly so don't notice the other post! I wouldn't usually post after such an informative post!
  • 06-24-2007 3:08 PM In reply to
    • Jandyt
    • Posts 13,004
    Well, bless you both anywayBig Smile
    Andy T.
  • 06-24-2007 4:39 PM In reply to
    I 'm afraid I don't multitask as well as Peter. Must get myself one of those Strawberry things he uses!Laughing
    Did you notice that although I posted first, he took all the applause!!!!Stick out tongue
    Regards Graham
  • 06-24-2007 5:10 PM In reply to
    LaughingLaughing
    Does seem a trifle unfair!
