Latest post 06-09-2010 1:17 PM by Douglas . 4 replies.
Page 1 of 1 (5 items)
  • 06-07-2010 2:26 PM
    BV7-40 MK2 software
    Hi All, just for info had my BV7 mk2 software updated to 30.03! from 7.00
    TV tuner can be turned off,! 4 STB controllers/PUCs are now active!(excellent) MLGWay can be set to on,.
    Its supposed to be for TVs only with DVB-HD module but works fine on mine without module.
    Douglas
  • 06-07-2010 3:48 PM In reply to
    Re: BV7-40 MK2 software
    Do you know how to check the version on a bv7-40 mk2?
    I have a V+ plus box, using a BEO5 remote and it is very painful to use and often switches the box off instead of on!
    Dan
  • 06-08-2010 1:01 PM In reply to
    Press menu
    Highlight options
    press Red then Go
    Highlight & Press go on Info
    AS number is the TV Application software number
    HD ready sets i.e MK2 started with 7.00
    Regards D
  • 06-09-2010 5:02 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Do you happen to have a full list of what the S/W update does? Mine runs 7.91e from memory.
    beoaus
  • 06-09-2010 1:17 PM In reply to
    Hi, Sorry  No list, but its not compatible with DVB-T or DVB-S modules! Regarding modules this software only works with DVB-HD!
    M2-Flash & AS-IC Chip must both be 33.03.
    I am able to turn off the TV Analogue tuner and use AppleTV from the TV button & PUC A-Remote on AV4- SUPER!
    HDMI expander is also there!
    BUT the BIG plus are the four PUCS
    Dougie
