Latest post 06-08-2010 3:16 PM by Peter. 5 replies.
Page 1 of 1 (6 items)
  • 06-07-2010 1:52 PM
    • Sunny
    • Not Ranked
    • Joined on 01-09-2009
    • New York
    • Posts 10
    AM/FM Antennas needed for Beomaster 5500 (USA)
    Finally have everything working in my Beosystem... except AM radio.
    Whats the easiest/cheapest way to get my AM radio working? A certain part on ebay? Something from Radio Shack? Sorry, I'm clueless here...
    I don't have an FM antenna either, so getting that working (more stations!) would be great.
    My priority is AM though.
    Thank you!
    CW
  • 06-07-2010 3:26 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: AM/FM Antennas needed for Beomaster 5500 (USA)
    I would ask yor nearest B&O dealer. I know they still sell the FM antenna so I see no reason why they won't sell the AM ones too.
    Chris.
  • 06-08-2010 4:17 AM In reply to
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    You should go for an active (powered) B&O AM antenna
    http://www.beoworld.org/prod_details.asp?pid=1003
    http://www.beocentral.com/products/am10
    I use one daily in Holland for BBC R4 LW and difference is quite remarkable.
    From the spec on Beoworld I don't see a 110v version so you may need a stepdown tranformer.
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 06-08-2010 10:26 AM In reply to
    • Sunny
    • Not Ranked
    • New York
    • Posts 10
    I have a call in to B&O... they are calling their repair shop (?)...
    I have seen that AM antenna, and while it looks amazing, and i'm sure preforms great, I have a feeling it is more money than I want to spend right now.
    I would think there would be a cheap alternative for sale at Radio Shack... I really just want to listen to baseball games and NPR. Amazing sound quality is not a priority (yet) here...
    What can I ask for at Radio Shack, or on ebay to get me something that works?
    Thanks for your suggestions so far.
  • 06-08-2010 2:23 PM In reply to
    • Medogsfat
    • Posts 4,045
    The FM antenna is now sold as a part for the Beosound Ouverture/3200 systems but will fit your beomaster by simply not using the extra bracket which comes with it & clipping it into the "V" at the back. The only thing with AM antenna's is finding one with the correct 2 pin plug, there's a genuine B&O one on ebay USA.
    Chris.
  • 06-08-2010 3:16 PM In reply to
    Long bit of wire and some Blu-Tac actually works surprisingly well!!
