1st March February 2012
Latest post 06-07-2010 6:37 AM by bhollenberg. 6 replies.
06-07-2010 4:53 AM
bhollenberg
- Joined on 09-21-2009
- Amsterdam
- Posts 27
specifications BeoVision 7-40 Mark V
Hi Guys,
Does anyone know what the specifications are of the new BeoVision 7-40 Mark V?
Kind regards,
Bas
My Bang & Olufsen....
- BeoVision 7-40 MK V
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
Michael
- Joined on 05-20-2009
- Glen Waverley, Victoria, Australia
- Posts 245
Re: specifications BeoVision 7-40 Mark V
Hi Bas,
Is this the one you mean? http://www.bang-olufsen.com/specifications?productid=746
Michael.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Bas,
The main specification areas are below:-
- DESIGNER is David Lewis
- DIMENSIONS are (W x H x D)/WEIGHT 108.0 x 68.0 x 18.0 cm + stand/45 kg 42.3" x 26.8" x 7.0" + stand approx. 99 lb
- COLOUR(S) Cabinet/Frame: Black/black, black/blue, black/dark grey, black/red, black/silver, black/golden, white/silver
- CONTRAST SCREEN Contrast screen with anti-reflection coating on both sides
- POWER CONSUMPTION EU: Typical: 202 W/Networked standby: 1 W US/Japan: Typical: 201 W/Networked standby: 0.9 W MAINS VOLTAGE RANGE EU: 200-240 V +10 / -15%, 50-60 Hz US/Japan 100-127 V +10 / -15%, 50-60 Hz
- THEFT PROTECTION FEATURE Pincode
- PICTURE FORMATS Format 1: 16:9 Panorama - 15:9 Panorama - 4:3, Format 2: Letterbox + Soft Scroll. Format 3: 16:9 Automatic format optimisation via "Black Bar Detection" 16:9 detection on all Scart connectors. Support of WSS (Wide Screen Signalling pulses) from broadcaster.
- HDMI INPUT FORMATS 480p,576p, 600p, 768p, 576i, 480i, 720p, 1080i, 1080p
- VGA INPUT FORMATS 60 Hz 640 × 480, 848 × 480, 1024 × 576, 800 × 600, 1024 × 768, 1366 × 768 and 1280 × 720
- DIGITAL SURROUND SOUND MODULE Standard built-in with SOUND INPUT FORMATS PCM, multichannel PCM Dolby Digital, Dolby Digital EX, DTS, DTS ES. Max 24 bit, 96 Khz
- DIGITAL SOUND DECODING CAPABILITIES Dolby Digital 5.1/EX 7.1, Dolby Pro Logic llx. DTS 5.1/ES 6.1/Neo:6 (US, Japan, KOR: AAC)
- SCREEN TYPE 40" 16:9 TFT LCD, glare surface
- BACK LIGHT TYPE Cold Cathode Fluorescent Lamp (CCFL)
- RESOLUTION 1920 x 1080 (Full HD)
- REFRESH RATE 200/240 Hz
- LUMINANCE OF WHITE (CENTRE OF SCREEN) Typical: 500 cd/m2
- CONTRAST RATIO at centre of screen Typical: 4000:1
- RESPONSE TIME (GREY TO GREY) Typical: 6 msec.
- VIEWING ANGLE +/-89 degrees both vertically and horizontally
- PICTURE OPTIMISATION VisionClear
- ROOM ADAPTATION Automatic Picture Control
- CONTRAST ENHANCEMENT Global backlight dimming
- MOTION PICTURE IMPROVEMENT Adaptive film judder compensation
- ANALOGUE TUNER VIDEO TYPE / FORMAT EU: Analogue: B/G/L/L/I/D/K PAL, SECAM (According to type and setup), NTSC on AV.
US/Japan/KOR: NTSC (M) FREQUENCY RANGE EU: 45 - 860 MHz: VHF, S-band, Hyper-band, UHF 99 programmes, auto tune, programme move and automatic naming US: Cable TV 1-125, Off Air TV 2-69 Japan: Channel 1-62 and Channel C13-C38
- ANALOGUE STEREO DECODING CAPABILITIES EU: A2 + Nicam Stereo US: BTSC Stereo, SAP Japan: EIA-J Stereo, AAC
- AERIAL INPUT CONNECTION(S) EU: TV: 1 x IEC-con female US/Japan/KOR: NTSC-M: 1 x F-con female
- DIGITAL TUNER T/C EU: Optional (DVB HD) US/Japan/KOR: Standard (ATCS module)
- VIDEO TYPE / FORMAT EU: DVB-HD module, DVB T/C, MPEG2/4, HD reception, EPG, Common Interface for Conditional Access and embedded CONAX (card pairing not supported) required for (de-)scrambling pay TV. US/Japan/KOR: ATSC Compliance ATSC A/53 rev. C, A/74 Mpeg2 (MP@ML (480P), MP@HL(720p, 1080i) ) Video formats all 18 according to ATSC A54a
- AUDIO TYPE / FORMAT EU: MPEG1, 2-channel audio decoder, layer 1 & 2 MPEG2, 2-channel audio decoder, layer 2
AAC, AAC+ AC3 decoding and down mix US/Japan/KOR: A (ATSC 052a) AC3 Stereo downmix Multichannel mode AC3 to S/P-DIF loop-through FREQUENCY, RANGE AND IF BANDWIDTH EU: 110 MHz to 862 MHz (Band 3, 4, 5) IF Bandwidth 6,7 & 8MHz selectable US/Japan/KOR: 54-806 MHz IF Bandwidth 6 MHz RASTER / FREQUENCY GRID EU: Special requirement for IT, TW and AUS US/J/KOR: COFDM (ORTHOGONAL FREQ. DIVISION MODULATION ) SPECTRUM EU: 2K & 8K, hierarchical and non hierarchical US/J/KOR:
- MODULATION EU: DVB-T: QPSK, 16QAM, 64QAM DVB-C: 4, 16, 64, 128, 256 QAM US/Japan/KOR: ATSC-T: 8VSB ATSC-C: 64QAM, 256QAM
- CODE RATE EU: 1/2, 2/3, 3/4, 5/6, 7/8 US/Japan/KOR:
- GUARD INTERVAL EU: 1/32, 1/16, 1/8, ¼ US/J/KOR:
- SYMBOL RATE EU: DVB-T: 2-45 msymb/sec DVB-C: 4.0-7.0 msymb/sec US/Japan/KOR: ATSC-T: 19,4 Mbit/sec ATSC-C: 5057 Msps (mode 1) or 5361 Msps (mode 2)
- AERIAL INPUT CONNECTION EU: DVB-HD (optional): 1 x IEC-con female Support of active aerial (DVB-T) 5V/50mA US/Japan/KOR:
ATSC:1 x F-con female
- USB EU: 1 x on the DVB-HD module (only for software update)
- ETHERNET EU:1 x RJ45 (software update)
- COMMON INTERFACE AND SMART CARD SLOTS EU: Common Interface according to EN50221 1x PCMCIA (Common Interface only)
Embedded CA: Conax (without Chip and Card paring), 1 Smart card slot connector All CA Systems available as common interface is supported CA power supply: 5V/500mA max.
- DIGITAL TUNER T/C/S2 EU: Optional US/KOR/Japan: Not available
- VIDEO TYPE / FORMAT DVB-HD T/C/S2 module, DVB T/C/S2, MPEG2/4, HD reception, EPG, Common Interface for Conditional Access and embedded CONAX (card pairing not supported) required for (de-)scrambling pay TV. AUDIO TYPE / FORMAT Mpeg1, Mpeg2, AAC, AAC+ and AC3 decoding and downmix FREQUENCY, RANGE AND IF BANDWIDTH S/S2: 10700-12750 MHz, IF Bandwidth 950-2150 MHz
T/C: 110 MHz to 862 MHz (Band 3, 4, 5) IF Bandwidth 6,7 & 8 MHz selectable Auto tuning 174-230 MHz and 470-858 MHz AERIAL INPUTS CONNECTION 1 x F-connector 1 x IEC-con female Support of active aerial (DVB-T) 5V/50mA ODU CONTROL DiSEqC 1.1
- USB USB 2.0 only for software update
- ETHERNET 1x RJ45 (for DVB-HD software update only)
- COMMON INTERFACE AND SMART CARD SLOTS Common Interface according to EN50221 1 x PCMCIA (Common Interface only)
Embedded CA: Conax (without Chip and Card pairing), 1 SmartCard slot connector All CA Systems available as common interface is supported CA power supply: 5 V/500 mA max.
- LOUDSPEAKER External (recommended: BeoLab 7-4 for centre or BeoLab 7-2 for stereo. Ordered separately)
bhollenberg
- Amsterdam
- Posts 27
Hi Michael,
That are still the specifications of the Mark IV, but this model will not be sold anymore........ (is told by my dealer in NL)
Kind regards.
Bas
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
bhollenberg
- Amsterdam
- Posts 27
Hi Keith,
Thanks for the overview.
So the main difference is the Refresh Rate of 200/240 Hz and the contrast ratio of 4000:1, compared to the Mark IV?
Kind regards,
Bas
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
Michael
- Posts 245
Sorry Bas. I just thought we had the latest info.
Apologies
Michael.
bhollenberg
- Amsterdam
- Posts 27
No worries!
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
Page 1 of 1 (7 items)
